Ga door naar hoofdinhoud
HP Compaq 6710b Keyboard Replacement
Wat je nodig hebt
  1. HP Compaq 6710b Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 HP Compaq 6710b Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 HP Compaq 6710b Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Compaq 6710b Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Compaq 6710b Keyboard Replacement: stap 3, afbeelding 1 van 2 HP Compaq 6710b Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Compaq 6710b Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Khulan Orgil
1.186 Reputatie
6 handleidingen geschreven
Cal Poly, Team 4-2, Maness Spring 2015 Lid van Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Leden
2Gids Commentaar
No parts required to *replace* the keyboard?
David - Antwoord Deel
Did you really need to be told to get a keyboard part to do a keyboard replacement?
Thanks for the guide
Victor Izquierdo Quesada - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 48
Altijd: 5,723
