Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the laptop over to the back.
Using two hands, push on the tabs while gently taking out the battery.
Flip to the backside of the laptop.
Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
Using the same screwdriver, unscrew the 8mm screws.
Flip over the laptop to the top side, and open the laptop.
Slide the locking tabs down using a blue plastic opening tool or your fingernail.
Using the plastic prying tool, lift the keyboard gently towards you.
Pull up on both sides of the black locking tab of the connector.
The keyboard should now be free of the computer.
Put a finger under each side of the plastic lock on the ribbon cable and pull up.
Using a flathead screwdriver, get under each plastic hinge cover until they pop.
Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
Using two fingers, open the prongs holding the RAM
Then slide the RAM out from the socket
Using a Phillips #1 screwdriver, unscrew the two 7mm screws on the top and bottom of the fan.
Using two fingers, pull out the fan power connector.
To take out the fan, lift the bottom of the fan and take it out at an angle.
Using the Phillips #1 screwdriver, unscrew the four screws on the copper plate.
9 andere personen hebben deze handleiding voltooid.
3 opmerkingen
That was easy. Thanks man :)
Piece of cake ! Thanks. :)
