Ga door naar hoofdinhoud
HP Chromebook CB2L Speaker Replacement
Wat je nodig hebt
  1. HP Chromebook CB2L Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 HP Chromebook CB2L Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
  2. HP Chromebook CB2L Speaker Replacement: stap 2, afbeelding 1 van 3 HP Chromebook CB2L Speaker Replacement: stap 2, afbeelding 2 van 3 HP Chromebook CB2L Speaker Replacement: stap 2, afbeelding 3 van 3
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
  3. HP Chromebook CB2L Speaker Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the battery input to the motherboard using the plastic opening tool
  4. HP Chromebook CB2L Speaker Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Speaker Replacement: stap 5, afbeelding 1 van 1
    • Using the plastic opening tool remove the battery from the Chromebook.
  6. HP Chromebook CB2L Speaker Replacement, Speaker: stap 6, afbeelding 1 van 1
    • Using the plastic opening tool lift the black tab.
    • Disconnect the blue and black strip from the motherboard.
  7. HP Chromebook CB2L Speaker Replacement: stap 7, afbeelding 1 van 1
    • Use the Phillips #1 screwdriver to remove the four 1.2mm screws circled red.
  8. HP Chromebook CB2L Speaker Replacement: stap 8, afbeelding 1 van 3 HP Chromebook CB2L Speaker Replacement: stap 8, afbeelding 2 van 3 HP Chromebook CB2L Speaker Replacement: stap 8, afbeelding 3 van 3
    • Gently pull the black wire to disconnect the audio port from the motherboard.
    • Disconnect the black wire connecting the speaker to the motherboard with caution.
  9. HP Chromebook CB2L Speaker Replacement: stap 9, afbeelding 1 van 1
    • Use the plastic opening tool to remove the speaker from back panel.
Conclusie
Gregory Hinkson
352 Reputatie
3 handleidingen geschreven
USF Tampa, Team S2-G6, Lacy Spring 2017 Lid van USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 143
