Inleiding
We are going to help you remove and replace a component of your HP Chromebook CB2L. The component that this guide helps you with is the Audio Port of the HP Chromebook CB2L. Please take a look at this troubleshooting page to confirm that this component needs replacement.
Wat je nodig hebt
First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
Next, using the plastic opening tool remove the blue panel.
Using the plastic opening tool lift the black tab.
Disconnect the blue and black strip from the motherboard.
Disconnect the black wire which connects the audio port to the motherboard.
Use the plastic opening tool to lift the white tab.
Use the plastic opening tool to disconnect the gold strip which connects the audio port to the motherboard.
