Ga door naar hoofdinhoud
HP Chromebook CB2L Keyboard Replacement
Wat je nodig hebt
  1. HP Chromebook CB2L Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Flip the Chromebook over so the blue panels are showing.
    • Starting in the top left or right corner, use the plastic opening tool to remove the large blue panel.
    • This piece has fragile plastic connectors. Don't damage them.
  2. HP Chromebook CB2L Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Chromebook CB2L Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Remove six 4.77mm screws using the Phillips #1 screwdriver.
  3. HP Chromebook CB2L Keyboard Replacement: stap 3, afbeelding 1 van 3 HP Chromebook CB2L Keyboard Replacement: stap 3, afbeelding 2 van 3 HP Chromebook CB2L Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Starting in the top right-hand corner of the exposed metal piece, use the blue plastic opening tool to remove the back panel.
  4. HP Chromebook CB2L Keyboard Replacement: stap 4, afbeelding 1 van 2 HP Chromebook CB2L Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Remove twenty 3.42mm screws with the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Keyboard Replacement: stap 5, afbeelding 1 van 2 HP Chromebook CB2L Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the black and white antennae wires, the white ribbon cables, the large black connecter, and the speaker cable from the motherboard.
    • Grabbing the boards by the edges, remove the motherboard and audio/USB board.
  6. HP Chromebook CB2L Keyboard Replacement: stap 6, afbeelding 1 van 3 HP Chromebook CB2L Keyboard Replacement: stap 6, afbeelding 2 van 3 HP Chromebook CB2L Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Remove the red and blue antennae wires from the SIM card board.
    • Remove the SIM card tray.
    • Flip the board over and use the plastic opening tool to remove the ribbon cable, then remove the board.
  7. HP Chromebook CB2L Keyboard Replacement: stap 7, afbeelding 1 van 2 HP Chromebook CB2L Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the speakers and battery.
  8. HP Chromebook CB2L Keyboard Replacement: stap 8, afbeelding 1 van 2 HP Chromebook CB2L Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Remove eighteen 2.5mm screws using the Phillips #1 screwdriver.
    • Flip the Chromebook so the top is on the table and the push out the keyboard from the back.
Conclusie
Nathan Petrie
277 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G4, Harley Fall 2018 Lid van IUPUI, Team S1-G4, Harley Fall 2018
IUPUI-HARLEY-F18S1G4
3 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 195
