Ga door naar hoofdinhoud
HP Chromebook 14-q029wm Fan Replacement
Wat je nodig hebt
  1. HP Chromebook 14-q029wm Fan Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Remove nine 5mm Phillips #0 screws from the back case.
    • Remove the rubber caps using a spudger.
    • Remove the four remaining 5mm Phillips #0 screws.
  2. HP Chromebook 14-q029wm Fan Replacement: stap 2, afbeelding 1 van 1
    • Use an opening tool to unclip the bottom plastic covering of the laptop.
    • Go around the sides of the laptop until the bottom unclips completely and comes off of the laptop.
    • Be careful not to break the plastic clips.
  3. HP Chromebook 14-q029wm Fan Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Once the bottom is completely unclipped, remove the covering slowly so you do not pull and rip the wires.
    • There is a little black lever that you have to pull in order to remove the wires. They are found on top of where the wires are connected.
    • Remove the larger wire first.
    • Then remove the smaller wire.
    • It is better to use a pair of tweezers for accuracy
    • From there the keyboard should completely come off.
  4. HP Chromebook 14-q029wm Fan Replacement, Battery: stap 4, afbeelding 1 van 1
    • Use your fingers to pull the white tab out of the black slot above the battery.
  5. HP Chromebook 14-q029wm Fan Replacement: stap 5, afbeelding 1 van 1
    • Remove the 3mm Phillips #0 screws.
  6. HP Chromebook 14-q029wm Fan Replacement: stap 6, afbeelding 1 van 1
    • Pick up and gently remove the battery.
  7. HP Chromebook 14-q029wm Fan Replacement, Fan: stap 7, afbeelding 1 van 2 HP Chromebook 14-q029wm Fan Replacement, Fan: stap 7, afbeelding 2 van 2
    • Remove the three 3mm Phillips #0 screws.
    • The bottom right screw may be covered by the fan's wires.
  8. HP Chromebook 14-q029wm Fan Replacement: stap 8, afbeelding 1 van 1
    • Using your fingers or an opening tool, remove the cable connecting the fan to the motherboard.
    • Gently remove the fan.
Conclusie
Andrew Pratt
669 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S1-G5, Barthe Fall 2019 Lid van UMass Dartmouth, Team S1-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S1G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 326
