Ga door naar hoofdinhoud
HP Chromebook 14-Q010DX USB/SD card Replacement
Wat je nodig hebt
  1. HP Chromebook 14-Q010DX USB/SD card Replacement, Keyboard and Touchpad: stap 1, afbeelding 1 van 2 HP Chromebook 14-Q010DX USB/SD card Replacement, Keyboard and Touchpad: stap 1, afbeelding 2 van 2
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Chromebook 14-Q010DX USB/SD card Replacement: stap 2, afbeelding 1 van 3 HP Chromebook 14-Q010DX USB/SD card Replacement: stap 2, afbeelding 2 van 3 HP Chromebook 14-Q010DX USB/SD card Replacement: stap 2, afbeelding 3 van 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Chromebook 14-Q010DX USB/SD card Replacement: stap 3, afbeelding 1 van 3 HP Chromebook 14-Q010DX USB/SD card Replacement: stap 3, afbeelding 2 van 3 HP Chromebook 14-Q010DX USB/SD card Replacement: stap 3, afbeelding 3 van 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Chromebook 14-Q010DX USB/SD card Replacement: stap 4, afbeelding 1 van 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Chromebook 14-Q010DX USB/SD card Replacement: stap 5, afbeelding 1 van 1
    • Set aside the detached keyboard.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: stap 6, afbeelding 1 van 3 HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: stap 6, afbeelding 2 van 3 HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: stap 6, afbeelding 3 van 3
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Chromebook 14-Q010DX USB/SD card Replacement: stap 7, afbeelding 1 van 2 HP Chromebook 14-Q010DX USB/SD card Replacement: stap 7, afbeelding 2 van 2
    • Gently remove the speakers.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Chromebook 14-Q010DX USB/SD card Replacement, Battery: stap 8, afbeelding 1 van 2 HP Chromebook 14-Q010DX USB/SD card Replacement, Battery: stap 8, afbeelding 2 van 2
    • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
    • Lift the black flaps and gently pull the strip out.
    • Set the strip aside.
    Vraag FixBot
    Voeg opmerking toe
  9. HP Chromebook 14-Q010DX USB/SD card Replacement: stap 9, afbeelding 1 van 3 HP Chromebook 14-Q010DX USB/SD card Replacement: stap 9, afbeelding 2 van 3 HP Chromebook 14-Q010DX USB/SD card Replacement: stap 9, afbeelding 3 van 3
    • Remove the screw.
    • Use your fingers to pull the white tab out of the black slot above the battery.
    Vraag FixBot
    Voeg opmerking toe
  10. HP Chromebook 14-Q010DX USB/SD card Replacement: stap 10, afbeelding 1 van 1
    • Gently remove battery.
    Vraag FixBot
    Voeg opmerking toe
  11. HP Chromebook 14-Q010DX USB/SD card Replacement, USB/SD card: stap 11, afbeelding 1 van 2 HP Chromebook 14-Q010DX USB/SD card Replacement, USB/SD card: stap 11, afbeelding 2 van 2
    • Remove screw indicated by the red circle at the top of the card port.
    Vraag FixBot
    Voeg opmerking toe
  12. HP Chromebook 14-Q010DX USB/SD card Replacement: stap 12, afbeelding 1 van 1
    • Gently remove the USB/SD card port.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Kevin Piper
1.602 Reputatie
6 handleidingen geschreven
USF Tampa, Team 17-2, Watkins Winter 2015 Lid van USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 783
