Ga door naar hoofdinhoud
HP Chromebook 14-Q010DX Motherboard Replacement
Wat je nodig hebt
  1. HP Chromebook 14-Q010DX Motherboard Replacement, Keyboard and Touchpad: stap 1, afbeelding 1 van 2 HP Chromebook 14-Q010DX Motherboard Replacement, Keyboard and Touchpad: stap 1, afbeelding 2 van 2
    • Flip the laptop so the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew the 13 screws.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Chromebook 14-Q010DX Motherboard Replacement: stap 2, afbeelding 1 van 3 HP Chromebook 14-Q010DX Motherboard Replacement: stap 2, afbeelding 2 van 3 HP Chromebook 14-Q010DX Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Chromebook 14-Q010DX Motherboard Replacement: stap 3, afbeelding 1 van 3 HP Chromebook 14-Q010DX Motherboard Replacement: stap 3, afbeelding 2 van 3 HP Chromebook 14-Q010DX Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Chromebook 14-Q010DX Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Chromebook 14-Q010DX Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Set aside the detached keyboard.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: stap 6, afbeelding 1 van 3 HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: stap 6, afbeelding 2 van 3 HP Chromebook 14-Q010DX Motherboard Replacement, Speaker: stap 6, afbeelding 3 van 3
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Chromebook 14-Q010DX Motherboard Replacement: stap 7, afbeelding 1 van 2 HP Chromebook 14-Q010DX Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Gently remove the speakers.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Chromebook 14-Q010DX Motherboard Replacement, Battery: stap 8, afbeelding 1 van 2 HP Chromebook 14-Q010DX Motherboard Replacement, Battery: stap 8, afbeelding 2 van 2
    • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
    • Lift the black flaps and gently pull the strip out.
    • Set the strip aside.
    Vraag FixBot
    Voeg opmerking toe
  9. HP Chromebook 14-Q010DX Motherboard Replacement: stap 9, afbeelding 1 van 3 HP Chromebook 14-Q010DX Motherboard Replacement: stap 9, afbeelding 2 van 3 HP Chromebook 14-Q010DX Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Remove the screw.
    • Use your fingers to pull the white tab out of the black slot above the battery.
    Vraag FixBot
    Voeg opmerking toe
  10. HP Chromebook 14-Q010DX Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Gently remove battery.
    Vraag FixBot
    Voeg opmerking toe
  11. HP Chromebook 14-Q010DX Motherboard Replacement, Bluetooth and Wireless Card: stap 11, afbeelding 1 van 2 HP Chromebook 14-Q010DX Motherboard Replacement, Bluetooth and Wireless Card: stap 11, afbeelding 2 van 2
    • Using a spudger, remove the white and black cables from the card.
    Vraag FixBot
    Voeg opmerking toe
  12. HP Chromebook 14-Q010DX Motherboard Replacement: stap 12, afbeelding 1 van 2 HP Chromebook 14-Q010DX Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Remove screw from card.
    Vraag FixBot
    Voeg opmerking toe
  13. HP Chromebook 14-Q010DX Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Gently pull card at a 45° angle to remove it.
    Vraag FixBot
    Voeg opmerking toe
  14. HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: stap 14, afbeelding 1 van 3 HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: stap 14, afbeelding 2 van 3 HP Chromebook 14-Q010DX Motherboard Replacement, Fan replacement for a HP Chromebook: stap 14, afbeelding 3 van 3
    • Remove the 3 screws around the fan.
    • Using your fingers or the spudger, disconnect the cable connecting the fan to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  15. HP Chromebook 14-Q010DX Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Once the cable connecting the fan to the motherboard is revomed gently remove fan with hands.
    Vraag FixBot
    Voeg opmerking toe
  16. HP Chromebook 14-Q010DX Motherboard Replacement, Motherboard: stap 16, afbeelding 1 van 2 HP Chromebook 14-Q010DX Motherboard Replacement, Motherboard: stap 16, afbeelding 2 van 2
    • Using your fingers or spudger, pull out the connector.
    Vraag FixBot
    Voeg opmerking toe
  17. HP Chromebook 14-Q010DX Motherboard Replacement: stap 17, afbeelding 1 van 3 HP Chromebook 14-Q010DX Motherboard Replacement: stap 17, afbeelding 2 van 3 HP Chromebook 14-Q010DX Motherboard Replacement: stap 17, afbeelding 3 van 3
    • Remove all of the indicated screws.
    • Pull up on black strip to remove the monitor cord.
    Vraag FixBot
    Voeg opmerking toe
  18. HP Chromebook 14-Q010DX Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Gently remove motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Kevin Piper
1.602 Reputatie
6 handleidingen geschreven
USF Tampa, Team 17-2, Watkins Winter 2015 Lid van USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Leden
8 handleidingen geschreven
4Gids Commentaar
Can someone just explain for what the sensor board is needed?
martindoerflinger - Antwoord Deel
Let's the motherboard know when the lid is closed.
Jeff Briedwell - Antwoord Deel
Hi! How do you start a chrome book from motherboard? Since I am doing a project I need help with that question.... Please send a mail with the explanation on my mail: steffe010929@gmail.con
Stefan - Antwoord Deel
hope some one is still maintaining this site, i would like to know if i would be able to use a motherboard from another HP chromebook in the same product line for example if i have a motherboard from the 14-q010dx can i swap it with the motherboard from the 14-q010nr? thevet82@gmail.com
david saldivias - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 5,114
