Inleiding
This guide will require removal of 1x5mm screws. Be careful removing the wires, be sure to release them as instructed before pulling on them.
Wat je nodig hebt
Flip the laptop so the base of the laptop is facing you.
Using the #00 screwdriver, unscrew the 13 screws.
Undo the black tape located on the bottom from the frame of the laptop.
Using fingers or the spudger, slide out the black connector indicated on the left.
Use a #00 screwdriver to remove the two screws.
6 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
Nice guide, guys!
Thanks, hope it made life a bit easier for you!
Very clear and concise. Nice going! Thank you.
