Ga door naar hoofdinhoud
HP Chromebook 11A G8 EE Bezel Replacement
Wat je nodig hebt
  1. HP Chromebook 11A G8 EE Bezel Replacement, Keyboard Assembly: stap 1, afbeelding 1 van 2 HP Chromebook 11A G8 EE Bezel Replacement, Keyboard Assembly: stap 1, afbeelding 2 van 2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Bezel Replacement: stap 2, afbeelding 1 van 3 HP Chromebook 11A G8 EE Bezel Replacement: stap 2, afbeelding 2 van 3 HP Chromebook 11A G8 EE Bezel Replacement: stap 2, afbeelding 3 van 3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Bezel Replacement: stap 3, afbeelding 1 van 2 HP Chromebook 11A G8 EE Bezel Replacement: stap 3, afbeelding 2 van 2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
  4. HP Chromebook 11A G8 EE Bezel Replacement, Bezel: stap 4, afbeelding 1 van 1
    • Pry the hinge cap off with your hands by lifting it up.
  5. HP Chromebook 11A G8 EE Bezel Replacement: stap 5, afbeelding 1 van 1
    • Use the iFixit opening tool to pry the bezel up.
  6. HP Chromebook 11A G8 EE Bezel Replacement: stap 6, afbeelding 1 van 1
    • Once you have pried away the bezel, pull it up towards you.
    • Peel it off gently from the screen.
  7. HP Chromebook 11A G8 EE Bezel Replacement: stap 7, afbeelding 1 van 1
    • You are finished once the bezel is off of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kim Travers
523 Reputatie
2 handleidingen geschreven
Één opmerking
Just curious why the back needs to be unscrewed and the keyboard removed to take off the bezel.
The spine piece can be removed with the device closed.
Also, the bezel is attached with a lot of adhesive. Be extremely careful to not break the bezel when removing it.
Scott - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 22
Altijd: 627
