Ga door naar hoofdinhoud
HP Chromebook 11-v019wm Touch Display Replacement
Wat je nodig hebt
  1. HP Chromebook 11-v019wm Touch Display Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Disconnect the power adapter from the charging port and remove all external media devices from the Chromebook.
    • Turn the Chromebook over so the bottom of the computer is facing upwards with the hinge facing away.
  2. HP Chromebook 11-v019wm Touch Display Replacement: stap 2, afbeelding 1 van 2 HP Chromebook 11-v019wm Touch Display Replacement: stap 2, afbeelding 2 van 2
    • Remove the (4) rubber feet with the plastic spudger to reveal the screws underneath.
    • The rubber feet are secured with adhesive and may take time to remove.
  3. HP Chromebook 11-v019wm Touch Display Replacement: stap 3, afbeelding 1 van 2 HP Chromebook 11-v019wm Touch Display Replacement: stap 3, afbeelding 2 van 2
    • Remove the (2), oval shaped, rubber screw protectors near the hinge of the Chromebook.
    • The rubber screw protectors are secured with adhesive and may take time to remove.
  4. HP Chromebook 11-v019wm Touch Display Replacement: stap 4, afbeelding 1 van 2 HP Chromebook 11-v019wm Touch Display Replacement: stap 4, afbeelding 2 van 2
    • Remove the (11) 5.2 mm screws using a Phillips #00 Screwdriver.
  5. HP Chromebook 11-v019wm Touch Display Replacement: stap 5, afbeelding 1 van 2 HP Chromebook 11-v019wm Touch Display Replacement: stap 5, afbeelding 2 van 2
    • Place the Chromebook upright and open the screen all the way.
    • Starting towards the hinge, insert the spudger between the silver keyboard decking and the charcoal colored casing.
    • Pry upwards to release the tabs that are securing the keyboard to the casing.
    • Repeat this process around the perimeter of the keyboard to ensure all tabs are released.
    • Once all the tabs are released, gently lift the keyboard to gain access to the (2) Zero Insertion Force (ZIF) ribbon cables.
  6. HP Chromebook 11-v019wm Touch Display Replacement: stap 6, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 6, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    • Using the hook on the Halberd Spudger, lift up the ZIF connector tab for the keyboard ribbon cable. They keyboard ribbon cable is the larger of the two ribbon cables.
    • The remaining steps should be completed with the anti-static wrist strap to prevent damage to electrostatic discharge (ESD) sensitive components.
  7. HP Chromebook 11-v019wm Touch Display Replacement: stap 7, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 7, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 7, afbeelding 3 van 3
    • With the ZIF connector tab in the upright position, use your fingers to gently pull the keyboard ribbon cable out of the ZIF connector.
  8. HP Chromebook 11-v019wm Touch Display Replacement: stap 8, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 8, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 8, afbeelding 3 van 3
    • With the hook on the Halberd Spudger, lift the ZIF connector that is holding the Touchpad ribbon cable. The Touchpad ribbon cable is the smaller of the two ribbon cables.
  9. HP Chromebook 11-v019wm Touch Display Replacement: stap 9, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 9, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 9, afbeelding 3 van 3
    • With the ZIF connector tab in the upright position, use your fingers to gently pull the Touchpad ribbon cable out of the ZIF connector.
  10. HP Chromebook 11-v019wm Touch Display Replacement: stap 10, afbeelding 1 van 1
    • With both ribbon cables disconnected, the keyboard can now be safely removed from the Chromebook.
  11. HP Chromebook 11-v019wm Touch Display Replacement, Battery: stap 11, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement, Battery: stap 11, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement, Battery: stap 11, afbeelding 3 van 3
    Halberd Spudger
    $2.99
    • Using the hook on the halberd spudger, lift the external media board ZIF connector attached to the motherboard.
    • The external media ribbon cable spans across the battery and is connected to the external media board on the left, and motherboard on the right.
  12. HP Chromebook 11-v019wm Touch Display Replacement: stap 12, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 12, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 12, afbeelding 3 van 3
    • With the external media board ZIF connector lifted, using your fingers, gently remove the media cable from the motherboard.
  13. HP Chromebook 11-v019wm Touch Display Replacement: stap 13, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 13, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 13, afbeelding 3 van 3
    • Using the hook on the halberd spudger lift the ZIF connector on the External Media Board.
  14. HP Chromebook 11-v019wm Touch Display Replacement: stap 14, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 14, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 14, afbeelding 3 van 3
    • With the ZIF connector in the upright position, use your fingers to gently remove the media cable completely from the computer assembly.
  15. HP Chromebook 11-v019wm Touch Display Replacement: stap 15, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 15, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 15, afbeelding 3 van 3
    • Use either end of the spudger to remove the battery bundled cable connector from the motherboard.
  16. HP Chromebook 11-v019wm Touch Display Replacement: stap 16, afbeelding 1 van 2 HP Chromebook 11-v019wm Touch Display Replacement: stap 16, afbeelding 2 van 2
    • Using a Phillips #00 Screwdriver, remove the two silver 3.4 mm screws from the battery.
    • Using a Phillips #00 Screwdriver, remove the black 4.8 mm screw from the battery. This screw also secures the left speaker to the casing.
  17. HP Chromebook 11-v019wm Touch Display Replacement: stap 17, afbeelding 1 van 2 HP Chromebook 11-v019wm Touch Display Replacement: stap 17, afbeelding 2 van 2
    • Gently lift the battery out of the casing.
    • The WLAN Antenna cables run through a tab in the top left corner of the battery. To avoid damaging the cable, ensure the WLAN Antenna cables are out of the way before removing the battery.
  18. HP Chromebook 11-v019wm Touch Display Replacement, Touch Display: stap 18, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement, Touch Display: stap 18, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement, Touch Display: stap 18, afbeelding 3 van 3
    Halberd Spudger
    $2.99
    • Using the hook on the halberd spudger, gently lift up the ZIF connector tab that connects the Hall Sensor Board ribbon cable to the Motherboard.
  19. HP Chromebook 11-v019wm Touch Display Replacement: stap 19, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 19, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 19, afbeelding 3 van 3
    • With the ZIF connector tab in the upright position, gently pinch the blue lifting tab and remove the Hall Sensor ribbon cable from the ZIF connector.
  20. HP Chromebook 11-v019wm Touch Display Replacement: stap 20, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 20, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 20, afbeelding 3 van 3
    • Using your fingers or the hook on the halberd spudger, gently lift up the clear plastic sticker to reveal the ZIF connector securing the LVDS Touch Display to the Motherboard.
    • This step is only performed to gain access to the Touch Display ZIF connector. Not all Chromebook's may have this plastic sticker covering the ZIF Connector. If there is no plastic sticker, this step may be skipped.
  21. HP Chromebook 11-v019wm Touch Display Replacement: stap 21, afbeelding 1 van 2 HP Chromebook 11-v019wm Touch Display Replacement: stap 21, afbeelding 2 van 2
    • Using the hook on the halberd spudger, gently lift the ZIF connector tab securing the Touch Display LVDS cable to the Motherboard.
  22. HP Chromebook 11-v019wm Touch Display Replacement: stap 22, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 22, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 22, afbeelding 3 van 3
    • With the ZIF connector tab in the upright position, gently remove the Touch Display LVDS cable from the ZIF connector.
  23. HP Chromebook 11-v019wm Touch Display Replacement: stap 23, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 23, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 23, afbeelding 3 van 3
    • Using your fingers or the hook on the halberd spudger, gently lift up on the plastic sticker to reveal the Webcam ZIF connector.
    • This step is only performed to gain access to the Webcam ZIF connector. Not all Chromebook's may have this plastic sticker covering the ZIF connector. If there is no plastic sticker, this step may be skipped.
  24. HP Chromebook 11-v019wm Touch Display Replacement: stap 24, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 24, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 24, afbeelding 3 van 3
    • Using the hook on the halberd spudger, gently lift the Webcam ZIF connector tab.
  25. HP Chromebook 11-v019wm Touch Display Replacement: stap 25, afbeelding 1 van 2 HP Chromebook 11-v019wm Touch Display Replacement: stap 25, afbeelding 2 van 2
    • With the Webcam ZIF connector tab in the upright position, gently pinch the black lifting tab and remove the connector from the ZIF connector on the motherboard.
  26. HP Chromebook 11-v019wm Touch Display Replacement: stap 26, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 26, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 26, afbeelding 3 van 3
    • With either end of the spudger, remove the charging port cable from the bundle connector on the motherboard.
    • If the connector does not move when pushing on one side, push the other side to evenly remove the connector.
  27. HP Chromebook 11-v019wm Touch Display Replacement: stap 27, afbeelding 1 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 27, afbeelding 2 van 3 HP Chromebook 11-v019wm Touch Display Replacement: stap 27, afbeelding 3 van 3
    • Using the fine point of the spudger, gently lift up the (2) antenna coaxial connectors on the WLAN module.
    • The (2) antenna cables run along the top of the Chromebook casing and are attached to the Touch Display. Make sure the antenna cables are removed from their routing tabs to avoid damaging the cables.
  28. HP Chromebook 11-v019wm Touch Display Replacement: stap 28, afbeelding 1 van 2 HP Chromebook 11-v019wm Touch Display Replacement: stap 28, afbeelding 2 van 2
    • Using the Phillips #00 Screwdriver, remove the (4) 4.6mm screws from the left and right mounting brackets.
    • The mounting brackets secure the touch display to the base of the Chromebook. Use one hand to support the display before removing the final screw to ensure the display doesn't fall backwards after the screws have been removed.
  29. HP Chromebook 11-v019wm Touch Display Replacement: stap 29, afbeelding 1 van 2 HP Chromebook 11-v019wm Touch Display Replacement: stap 29, afbeelding 2 van 2
    • With one hand holding the base of the Chromebook, use the other hand to lift the display away from the base.
    • This step may require the display to be slightly compressed forward so the display mounts can clear the back of the base.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 371
