Ga door naar hoofdinhoud
HP Chromebook 11 G4 Keyboard Replacement
Wat je nodig hebt
    1. HP Chromebook 11 G4 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
      • Position the closed Chromebook with the rubber pads are facing up.
      Vraag FixBot
      Voeg opmerking toe
    2. HP Chromebook 11 G4 Keyboard Replacement: stap 2, afbeelding 1 van 2 HP Chromebook 11 G4 Keyboard Replacement: stap 2, afbeelding 2 van 2
      • Slide the flat end of the spudger under the rubber pads at the upper right-hand and the upper left-hand corners.
      • Pry off the rubber pads to reveal a screw under each pad.
      • The rubber pads are attached with a strong adhesive. The force applied may damage the pads.
      Vraag FixBot
      Voeg opmerking toe
    3. HP Chromebook 11 G4 Keyboard Replacement: stap 3, afbeelding 1 van 2 HP Chromebook 11 G4 Keyboard Replacement: stap 3, afbeelding 2 van 2
      • Remove the eleven 6mm Phillips #1 screws.
      Vraag FixBot
      Voeg opmerking toe
    4. HP Chromebook 11 G4 Keyboard Replacement: stap 4, afbeelding 1 van 1
      • Flip over the Chromebook and open it.
      Vraag FixBot
      Voeg opmerking toe
    5. HP Chromebook 11 G4 Keyboard Replacement: stap 5, afbeelding 1 van 2 HP Chromebook 11 G4 Keyboard Replacement: stap 5, afbeelding 2 van 2
      • Insert the flat end of the spudger between the bottom body of the Chromebook and keyboard body.
      • Slide the spudger along the gap, applying downward pressure to separate the two components.
      • You should hear popping sounds as you slide the spudger along the edge.
      • If the spudger gets stuck while sliding, simply slide the spudger back for a bit, and continue sliding forward.
      Vraag FixBot
      Voeg opmerking toe
    6. HP Chromebook 11 G4 Keyboard Replacement: stap 6, afbeelding 1 van 1
      • Lift the bottom of the keyboard assembly to reveal the internal components of the device.
      Vraag FixBot
      Voeg opmerking toe
    7. HP Chromebook 11 G4 Keyboard Replacement: stap 7, afbeelding 1 van 3 HP Chromebook 11 G4 Keyboard Replacement: stap 7, afbeelding 2 van 3 HP Chromebook 11 G4 Keyboard Replacement: stap 7, afbeelding 3 van 3
      • Use the pointed end of the spudger to flip up the black tabs on the two ZIF connectors located on the motherboard.
      • Disconnect the ribbon cables from the motherboard by gently sliding them out of their sockets.
      Vraag FixBot
      Voeg opmerking toe
    8. HP Chromebook 11 G4 Keyboard Replacement: stap 8, afbeelding 1 van 1
      • Remove the keyboard assembly by lifting it off the laptop base.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jair Herrera
694 Reputatie
4 handleidingen geschreven
3Gids Commentaar
How do you remove the keyboard from the assembly though? And I wish there was a mention of the fact that the heat sink is attached to the keyboard assembly.
Kyle B - Antwoord Deel
Same question as the person above. I need to remove the keyboard from the assembly.
Stephen Mason - Antwoord Deel
If you look up the parts you'll see that the entire top panel and keyboard are one assembly.
Nacho Biniz - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 58
Altijd: 10,131
