Ga door naar hoofdinhoud
HP Chromebook 11 G3 Camera Replacement
Wat je nodig hebt
  1. HP Chromebook 11 G3 Camera Replacement, Keyboard Mount: stap 1, afbeelding 1 van 2 HP Chromebook 11 G3 Camera Replacement, Keyboard Mount: stap 1, afbeelding 2 van 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
    Vraag FixBot
    Voeg opmerking toe
  2. HP Chromebook 11 G3 Camera Replacement: stap 2, afbeelding 1 van 2 HP Chromebook 11 G3 Camera Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
    Vraag FixBot
    Voeg opmerking toe
  3. HP Chromebook 11 G3 Camera Replacement: stap 3, afbeelding 1 van 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
    Vraag FixBot
    Voeg opmerking toe
  4. HP Chromebook 11 G3 Camera Replacement: stap 4, afbeelding 1 van 3 HP Chromebook 11 G3 Camera Replacement: stap 4, afbeelding 2 van 3 HP Chromebook 11 G3 Camera Replacement: stap 4, afbeelding 3 van 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
    Vraag FixBot
    Voeg opmerking toe
  5. HP Chromebook 11 G3 Camera Replacement: stap 5, afbeelding 1 van 1
    • Lift the keyboard mount out of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  6. HP Chromebook 11 G3 Camera Replacement, Display Assembly: stap 6, afbeelding 1 van 1
    • Gently tug on the black and white wires connected to the Wi-Fi module to disconnect them.
    Vraag FixBot
    Voeg opmerking toe
  7. HP Chromebook 11 G3 Camera Replacement: stap 7, afbeelding 1 van 2 HP Chromebook 11 G3 Camera Replacement: stap 7, afbeelding 2 van 2
    • Using a spudger, lift the ZIF retaining flap that secures the display’s ribbon cable to the motherboard.
    • Gently pull the ribbon cable out of its socket.
    Vraag FixBot
    Voeg opmerking toe
  8. HP Chromebook 11 G3 Camera Replacement: stap 8, afbeelding 1 van 1
    • Free the wire from the casing.
    Vraag FixBot
    Voeg opmerking toe
  9. HP Chromebook 11 G3 Camera Replacement: stap 9, afbeelding 1 van 1
    • Remove the two 6mm Phillips #00 screws located near the upper left and right corners of the hinge mounts.
    • Hold the lid so that it is folded slightly inwards while removing the screws so that the lid doesn’t fall.
    Vraag FixBot
    Voeg opmerking toe
  10. HP Chromebook 11 G3 Camera Replacement: stap 10, afbeelding 1 van 1
    • Rotate the lid to a 90-degree angle with the table.
    • Shimmy the lid out of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  11. HP Chromebook 11 G3 Camera Replacement, Screen Bezel: stap 11, afbeelding 1 van 3 HP Chromebook 11 G3 Camera Replacement, Screen Bezel: stap 11, afbeelding 2 van 3 HP Chromebook 11 G3 Camera Replacement, Screen Bezel: stap 11, afbeelding 3 van 3
    • Use the plastic opening tool to pry the left and right side of the top of the lid, and proceed inwards from the sides.
    • Do not attempt to remove the entire frame; this isn't necessary for removing the camera.
    • Do not pry at the center of the lid; this may damage the camera inside.
    Vraag FixBot
    Voeg opmerking toe
  12. HP Chromebook 11 G3 Camera Replacement, Camera: stap 12, afbeelding 1 van 1
    • Gently remove the slide-out connector near the bottom left corner of the camera mount.
    Vraag FixBot
    Voeg opmerking toe
  13. HP Chromebook 11 G3 Camera Replacement: stap 13, afbeelding 1 van 1
    • Locate the two silver strips of tape on each edge of the camera mount.
    • Use tweezers to peel off these strips.
    Vraag FixBot
    Voeg opmerking toe
  14. HP Chromebook 11 G3 Camera Replacement: stap 14, afbeelding 1 van 1
    • Use a plastic opening tool to pry the camera mount out of the lid.
    • Apply force evenly to prevent bending the mount.
    Vraag FixBot
    Voeg opmerking toe
  15. HP Chromebook 11 G3 Camera Replacement: stap 15, afbeelding 1 van 1
    • Lift the camera out of the lid.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Rahul Goyal
1.401 Reputatie
10 handleidingen geschreven
Cal Poly, Team S23-G3, Livingston Spring 2017 Lid van Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 1,462
