Ga door naar hoofdinhoud
HP 7 1800 Display Replacement
Wat je nodig hebt
    1. HP 7 1800 Display Replacement, Remove the back panel: stap 1, afbeelding 1 van 2 HP 7 1800 Display Replacement, Remove the back panel: stap 1, afbeelding 2 van 2
      • Carefully insert a Spudger into one of the corners of the tablet.
      • Slide the Spudger along the edge popping the tabs out along the way.
      • Be careful not to break the tabs.
      Vraag FixBot
      Voeg opmerking toe
    2. HP 7 1800 Display Replacement, Remove the battery: stap 2, afbeelding 1 van 3 HP 7 1800 Display Replacement, Remove the battery: stap 2, afbeelding 2 van 3 HP 7 1800 Display Replacement, Remove the battery: stap 2, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Slide the Spudger under the battery to lift it off the adhesive.
      • Gently pull the cable connection from the motherboard using tweezers.
      Vraag FixBot
      Voeg opmerking toe
    1. HP 7 1800 Display Replacement, Remove the large ribbon cable: stap 3, afbeelding 1 van 2 HP 7 1800 Display Replacement, Remove the large ribbon cable: stap 3, afbeelding 2 van 2
      • Remove the larger ribbon cable by gently flipping the beige latch and pulling it out with tweezers.
      Vraag FixBot
      Voeg opmerking toe
    2. HP 7 1800 Display Replacement, Remove the smaller ribbon cable: stap 4, afbeelding 1 van 2 HP 7 1800 Display Replacement, Remove the smaller ribbon cable: stap 4, afbeelding 2 van 2
      • Remove the smaller ribbon cable by gently flipping the black latch and pulling it out with tweezers.
      Vraag FixBot
      Voeg opmerking toe
    3. HP 7 1800 Display Replacement, Unscrew the 7 silver screws from the logic board: stap 5, afbeelding 1 van 1
      • Remove the following 7 screws:
      • Six 4.17mm Phillips #00 around the motherboard.
      • One 2.67mm Phillips #00 next to the front facing camera.
      • The 2.67mm screw circled in yellow is notably shorter than the other 6 screws circled in red.
      Vraag FixBot
      Voeg opmerking toe
    4. HP 7 1800 Display Replacement, Unplug the front facing camera from the logic board: stap 6, afbeelding 1 van 1
      • Gently pry the front facing camera plug up and off of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. HP 7 1800 Display Replacement, Remove the logic board: stap 7, afbeelding 1 van 1
      • Carefully lift the motherboard directly up.
      Vraag FixBot
      Voeg opmerking toe
    1. HP 7 1800 Display Replacement, Remove the ribbon cable attached to the metal plate: stap 8, afbeelding 1 van 2 HP 7 1800 Display Replacement, Remove the ribbon cable attached to the metal plate: stap 8, afbeelding 2 van 2
      • On the metal plate inside of the device, there is a ribbon cable in a loop. Flip the white tab and pull the cable out.
      Vraag FixBot
      Voeg opmerking toe
    2. HP 7 1800 Display Replacement, Unscrew the 7 black screws on the metal plate: stap 9, afbeelding 1 van 1
      • Unscrew the following black screws:
      • Seven 2.82mm Phillips #00 around the metal casing.
      Vraag FixBot
      Voeg opmerking toe
    3. HP 7 1800 Display Replacement, Remove the metal plate: stap 10, afbeelding 1 van 1
      • Gently lift the metal plate directly up.
      Vraag FixBot
      Voeg opmerking toe
    4. HP 7 1800 Display Replacement, Remove the display: stap 11, afbeelding 1 van 1
      • Gently lift the display directly up.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
TMD
792 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-1, Brown Winter 2015 Lid van USF Tampa, Team 4-1, Brown Winter 2015
USFT-BROWN-W15S4G1
4 Leden
14 handleidingen geschreven
2Gids Commentaar
I have this same tablet but I cannot find a replacement screen. Do you know where I could find one?
Karen Porter - Antwoord Deel
I have the same problem
akiel panchan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 2,262
