Ga door naar hoofdinhoud
HP 2000 - 2D22DX RAM Replacement
Wat je nodig hebt
  1. HP 2000 - 2D22DX RAM Replacement, Battery: stap 1, afbeelding 1 van 2 HP 2000 - 2D22DX RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the device over and locate the battery compartment.
    • Slide the battery release latch to the left until the battery is detached from its slot.
    • A distinguishable pop will be heard when the battery is fully released.
    Vraag FixBot
    Voeg opmerking toe
  2. HP 2000 - 2D22DX RAM Replacement: stap 2, afbeelding 1 van 2 HP 2000 - 2D22DX RAM Replacement: stap 2, afbeelding 2 van 2
    • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
    Vraag FixBot
    Voeg opmerking toe
  3. HP 2000 - 2D22DX RAM Replacement, RAM: stap 3, afbeelding 1 van 2 HP 2000 - 2D22DX RAM Replacement, RAM: stap 3, afbeelding 2 van 2
    • After battery removal, the RAM compartment cover is exposed.
    • Locate the Phillips head screw seen in the second picture. It secures the RAM compartment to the plastic chassis.
    • Loosen the screw that is securing the RAM compartment with a Phillips #00 screwdriver.
    • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
    Vraag FixBot
    Voeg opmerking toe
  4. HP 2000 - 2D22DX RAM Replacement: stap 4, afbeelding 1 van 2 HP 2000 - 2D22DX RAM Replacement: stap 4, afbeelding 2 van 2
    • Once the screw is sufficiently loosened, gently unclip the RAM compartment cover from its slots in the plastic chassis.
    • Pull the compartment door out and away from the chassis, exposing the black film covering the RAM module.
    Vraag FixBot
    Voeg opmerking toe
  5. HP 2000 - 2D22DX RAM Replacement: stap 5, afbeelding 1 van 3 HP 2000 - 2D22DX RAM Replacement: stap 5, afbeelding 2 van 3 HP 2000 - 2D22DX RAM Replacement: stap 5, afbeelding 3 van 3
    • Move the black plastic film to the side to locate the RAM slots.
    • Locate the metal clips holding the RAM card in place.
    • Using your fingers, push the metal clips out and away from the RAM module until the RAM module pops up at a 45 degree angle.
    Vraag FixBot
    Voeg opmerking toe
  6. HP 2000 - 2D22DX RAM Replacement: stap 6, afbeelding 1 van 1
    • Hold the black plastic film away from the RAM slots. Grasp the edge of the RAM card and slide it out at a 45 degree angle.
    • Maintain the 45 degree angle of the RAM card until all pins are disengaged. Failure to do so may result in pin breakage.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
7 andere personen hebben deze handleiding voltooid.
Conor Most
2.778 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-40, Maness Spring 2014 Lid van Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 48
Altijd: 4,315
