Ga door naar hoofdinhoud
HP 2000 - 2D22DX Hard Drive Replacement
Wat je nodig hebt
    1. HP 2000 - 2D22DX Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 HP 2000 - 2D22DX Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
      • Flip the device over and locate the battery compartment.
      • Slide the battery release latch to the left until the battery is detached from its slot.
      • A distinguishable pop will be heard when the battery is fully released.
      Vraag FixBot
      Voeg opmerking toe
    2. HP 2000 - 2D22DX Hard Drive Replacement: stap 2, afbeelding 1 van 2 HP 2000 - 2D22DX Hard Drive Replacement: stap 2, afbeelding 2 van 2
      • Slowly pull the battery out of its slot, being careful not to damage any of the connectors in the process.
      Vraag FixBot
      Voeg opmerking toe
    1. HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 2 HP 2000 - 2D22DX Hard Drive Replacement, Hard Drive: stap 3, afbeelding 2 van 2
      • Loosen the Phillips #00 screw securing the RAM compartment cover.
      • The screw is permanently attached to the RAM compartment cover. Do not try to remove it completely.
      Vraag FixBot
      Voeg opmerking toe
    2. HP 2000 - 2D22DX Hard Drive Replacement: stap 4, afbeelding 1 van 2 HP 2000 - 2D22DX Hard Drive Replacement: stap 4, afbeelding 2 van 2
      • Once the screw is sufficiently loosened, slowly unclip the RAM compartment cover from its slots in the plastic chassis.
      • When unclipped completely, pull the compartment door out and away from the chassis.
      Vraag FixBot
      Voeg opmerking toe
    3. HP 2000 - 2D22DX Hard Drive Replacement: stap 5, afbeelding 1 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 5, afbeelding 2 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 5, afbeelding 3 van 3
      • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
      • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
      • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
      Vraag FixBot
      Voeg opmerking toe
    4. HP 2000 - 2D22DX Hard Drive Replacement: stap 6, afbeelding 1 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 6, afbeelding 2 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 6, afbeelding 3 van 3
      • Using a spudger, disconnect the hard drive connecting cable. Use a slow, prying motion as if pulling a nail out of wood.
      • Be very gentle with the connecting cable and its respective port on the logic board. Both are very fragile and can be easily damaged.
      Vraag FixBot
      Voeg opmerking toe
    5. HP 2000 - 2D22DX Hard Drive Replacement: stap 7, afbeelding 1 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 7, afbeelding 2 van 3 HP 2000 - 2D22DX Hard Drive Replacement: stap 7, afbeelding 3 van 3
      • Using your fingers, grab the blue tab on the right side of the hard drive and slowly pull upwards.
      • Lift the hard drive out and away from its socket in the plastic chassis.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
27 andere personen hebben deze handleiding voltooid.
Conor Most
2.778 Reputatie
6 handleidingen geschreven
Cal Poly, Team 3-40, Maness Spring 2014 Lid van Cal Poly, Team 3-40, Maness Spring 2014
CPSU-MANESS-S14S3G40
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 64
Altijd: 15,720
