Ga door naar hoofdinhoud
HP 15-db0004dx Battery Replacement
Wat je nodig hebt
    1. HP 15-db0004dx Battery Replacement, Bottom Case: stap 1, afbeelding 1 van 2 HP 15-db0004dx Battery Replacement, Bottom Case: stap 1, afbeelding 2 van 2
      • Turn the laptop off and unplug it before starting.
      • Flip your laptop over, face down.
      Vraag FixBot
      Voeg opmerking toe
    2. HP 15-db0004dx Battery Replacement: stap 2, afbeelding 1 van 1
      • Peel off the two long rubber grips running lengthwise on the laptop.
      Vraag FixBot
      Voeg opmerking toe
    3. HP 15-db0004dx Battery Replacement: stap 3, afbeelding 1 van 2 HP 15-db0004dx Battery Replacement: stap 3, afbeelding 2 van 2
      • Using a Phillips #000 screwdriver, remove the eleven 10 mm screws located on the underside of the laptop, that are holding the back panel in place.
      Vraag FixBot
      Voeg opmerking toe
    4. HP 15-db0004dx Battery Replacement: stap 4, afbeelding 1 van 1
      • Carefully slide the optical drive out of the laptop.
      Vraag FixBot
      Voeg opmerking toe
    5. HP 15-db0004dx Battery Replacement: stap 5, afbeelding 1 van 1
      • Use a plastic opening tool to separate the back panel from the laptop.
      • For an easier removal, start at the corner and run the tool along the edge of the cover.
      • If you do not have a plastic opening tool, open it carefully using your hands, as shown.
      • Be careful to not bend the back panel, or to not apply too much pressure and force, doing so could cause the panel to break.
      Vraag FixBot
      Voeg opmerking toe
    1. HP 15-db0004dx Battery Replacement, Battery: stap 6, afbeelding 1 van 2 HP 15-db0004dx Battery Replacement, Battery: stap 6, afbeelding 2 van 2
      • Using the Philips #000 screwdriver remove all of the six 5mm screws.
      Vraag FixBot
      Voeg opmerking toe
    2. HP 15-db0004dx Battery Replacement: stap 7, afbeelding 1 van 3 HP 15-db0004dx Battery Replacement: stap 7, afbeelding 2 van 3 HP 15-db0004dx Battery Replacement: stap 7, afbeelding 3 van 3
      • Disconnect the battery connector.
      • Slide the battery up and out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 1,252
