Ga door naar hoofdinhoud
HP 15-da0002dx Battery Replacement
Wat je nodig hebt
  1. HP 15-da0002dx Battery Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure the computer is completely turned off.
  2. HP 15-da0002dx Battery Replacement: stap 2, afbeelding 1 van 1
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Battery Replacement: stap 3, afbeelding 1 van 2 HP 15-da0002dx Battery Replacement: stap 3, afbeelding 2 van 2
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
  4. HP 15-da0002dx Battery Replacement: stap 4, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Battery Replacement: stap 5, afbeelding 1 van 1
    • Carefully flip over the computer so the HP label is now facing the ceiling.
  6. HP 15-da0002dx Battery Replacement: stap 6, afbeelding 1 van 2 HP 15-da0002dx Battery Replacement: stap 6, afbeelding 2 van 2
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Battery Replacement: stap 7, afbeelding 1 van 1
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx Battery Replacement, Battery: stap 8, afbeelding 1 van 1
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
  9. HP 15-da0002dx Battery Replacement: stap 9, afbeelding 1 van 2 HP 15-da0002dx Battery Replacement: stap 9, afbeelding 2 van 2
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Abigail Aron
941 Reputatie
5 handleidingen geschreven
Één opmerking
Where to find, buy the same battery spare???
Divya Lekha - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 42
Altijd: 4,123
