Ga door naar hoofdinhoud
HP 15-ay078nr Screen Replacement
Wat je nodig hebt
  1. HP 15-ay078nr Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Open the lid of the laptop.
    • Feel the top of the laptop screen to find a ridge separating the front and back of the screen bezel.
    • Using an opening pick tool, gently pry the front screen bezel apart from the rear to release the internal plastic retention clips.
    • You may see small bits of plastic come loose from the screen bezel. This is not an issue and will not hurt the reassembly process.
  2. HP 15-ay078nr Screen Replacement: stap 2, afbeelding 1 van 2 HP 15-ay078nr Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 3.2 mm screws from the screen using a Phillips #2 screwdriver.
  3. HP 15-ay078nr Screen Replacement: stap 3, afbeelding 1 van 3 HP 15-ay078nr Screen Replacement: stap 3, afbeelding 2 van 3 HP 15-ay078nr Screen Replacement: stap 3, afbeelding 3 van 3
    • Gently lay the screen against the keyboard.
    • Disconnect the display cable from the rest of the laptop.
Conclusie
Power on your device to see the new screen. If the backlight is flickering, the LCD cable may have not been pushed in completely. Ensure it is fully connected.
Liberty DeAngelo
97 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 3-1, Sinclaire Fall 2021 Lid van UMass Dartmouth, Team 3-1, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G1
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 164
