Ga door naar hoofdinhoud
HP 15-R011DX Motherboard Replacement
Wat je nodig hebt
  1. HP 15-R011DX Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 HP 15-R011DX Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide the lock mechanism on the left side of the laptop to the right.
    Vraag FixBot
    Voeg opmerking toe
  2. HP 15-R011DX Motherboard Replacement: stap 2, afbeelding 1 van 1
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
    Vraag FixBot
    Voeg opmerking toe
  3. HP 15-R011DX Motherboard Replacement, How to Access the Internal Components of an HP 15-R011DX: stap 3, afbeelding 1 van 2 HP 15-R011DX Motherboard Replacement, How to Access the Internal Components of an HP 15-R011DX: stap 3, afbeelding 2 van 2
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
    Vraag FixBot
    Voeg opmerking toe
  4. HP 15-R011DX Motherboard Replacement: stap 4, afbeelding 1 van 2 HP 15-R011DX Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  5. HP 15-R011DX Motherboard Replacement: stap 5, afbeelding 1 van 2 HP 15-R011DX Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
    Vraag FixBot
    Voeg opmerking toe
  6. HP 15-R011DX Motherboard Replacement: stap 6, afbeelding 1 van 3 HP 15-R011DX Motherboard Replacement: stap 6, afbeelding 2 van 3 HP 15-R011DX Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  7. HP 15-R011DX Motherboard Replacement: stap 7, afbeelding 1 van 2 HP 15-R011DX Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
    Vraag FixBot
    Voeg opmerking toe
  8. HP 15-R011DX Motherboard Replacement, Hard Drive: stap 8, afbeelding 1 van 1
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
    Vraag FixBot
    Voeg opmerking toe
  9. HP 15-R011DX Motherboard Replacement: stap 9, afbeelding 1 van 2 HP 15-R011DX Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
    Vraag FixBot
    Voeg opmerking toe
  10. HP 15-R011DX Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
    Vraag FixBot
    Voeg opmerking toe
  11. HP 15-R011DX Motherboard Replacement, Motherboard: stap 11, afbeelding 1 van 2 HP 15-R011DX Motherboard Replacement, Motherboard: stap 11, afbeelding 2 van 2
    • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  12. HP 15-R011DX Motherboard Replacement: stap 12, afbeelding 1 van 1
    • Remove the tape from the display connector attached to the motherboard.
    • Disconnect the display connector from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  13. HP 15-R011DX Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Remove one 4 mm Phillips #1 screw from the wireless chip.
    • Remove the wireless chip from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  14. HP 15-R011DX Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
    • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
    Vraag FixBot
    Voeg opmerking toe
  15. HP 15-R011DX Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Slowly lift the motherboard out of the computer.
    • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
    • Disconnect the power connector from the motherboard as shown in the image.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Ethan Guillotte
517 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 Lid van UMass Dartmouth, Team S2-G4, Bailey Spring 2019
UMASSD-BAILEY-S19S2G4
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 931
