Ga door naar hoofdinhoud
HMDX Jam Battery Replacement
Wat je nodig hebt
    1. HMDX Jam Battery Replacement, Opening speaker: stap 1, afbeelding 1 van 1
      • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
      Vraag FixBot
      Voeg opmerking toe
    2. HMDX Jam Battery Replacement, remove rubber cover: stap 2, afbeelding 1 van 1
      • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
      Vraag FixBot
      Voeg opmerking toe
    3. HMDX Jam Battery Replacement, Remove screws: stap 3, afbeelding 1 van 1
      • Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
      • It would be wise to use a magnetic mat for the screws for safekeeping.
      Vraag FixBot
      Voeg opmerking toe
    4. HMDX Jam Battery Replacement, Exposing Battery: stap 4, afbeelding 1 van 1
      • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
      Vraag FixBot
      Voeg opmerking toe
    5. HMDX Jam Battery Replacement, Removing Battery: stap 5, afbeelding 1 van 1
      • Very gently remove the battery from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. HMDX Jam Battery Replacement, Remove battery attachments: stap 6, afbeelding 1 van 2 HMDX Jam Battery Replacement, Remove battery attachments: stap 6, afbeelding 2 van 2
      • Use a solder gun to remove the battery attachments from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
42 andere personen hebben deze handleiding voltooid.
Prince Tendai Dzonga
680 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-1, Blackwell Winter 2015 Lid van USF Tampa, Team 1-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G1
4 Leden
10 handleidingen geschreven
18Gids Commentaar
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Stephen Lavizzo - Antwoord Deel
Did you ever find out where to purchase a new battery for it?
DJ Ethics - Antwoord Deel
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
Lynchfield Daniel - Antwoord Deel
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
minhngoctruong - Antwoord Deel
My Bluetooth speaker just has a rubber suction on the bottom. There is no area to replace a battery. Is there any way to reset I?
bdale46 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 113
Altijd: 98,795
