Ga door naar hoofdinhoud
HMDX Chill Motherboard Replacement
Wat je nodig hebt
  1. HMDX Chill Motherboard Replacement, Remove Rubber Base: stap 1, afbeelding 1 van 3 HMDX Chill Motherboard Replacement, Remove Rubber Base: stap 1, afbeelding 2 van 3 HMDX Chill Motherboard Replacement, Remove Rubber Base: stap 1, afbeelding 3 van 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Motherboard Replacement: stap 3, afbeelding 1 van 2 HMDX Chill Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Motherboard Replacement, Motherboard: stap 4, afbeelding 1 van 3 HMDX Chill Motherboard Replacement, Motherboard: stap 4, afbeelding 2 van 3 HMDX Chill Motherboard Replacement, Motherboard: stap 4, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
  5. HMDX Chill Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Pull the motherboard away from the base gently.
    • Do not pull too hard on the motherboard. It is still attached to the base by wires.
  6. HMDX Chill Motherboard Replacement: stap 6, afbeelding 1 van 3 HMDX Chill Motherboard Replacement: stap 6, afbeelding 2 van 3 HMDX Chill Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Use a soldering iron to desolder the wires connecting the motherboard to the case.
  7. HMDX Chill Motherboard Replacement: stap 7, afbeelding 1 van 2 HMDX Chill Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Insert the spudger between the case and the wire and move the spudger upwards.
    • This will cause the case to prop open.
    • The wire behind the motherboard will now be visible. Pull this out from behind.
  8. HMDX Chill Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
Conclusie
Jourdan Holubasch
754 Reputatie
7 handleidingen geschreven
EWU-Giguere-S16S1G1 Lid van EWU-Giguere-S16S1G1
Community
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 357
