Ga door naar hoofdinhoud
HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup)
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
  1. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup), Bacterial Filter: stap 1, afbeelding 1 van 1
    • Orient Hamilton-C1 so the right side of the device is facing you.
  2. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): stap 2, afbeelding 1 van 1
    • Disconnect used/contaminated INSPIRATORY bacterial filter from circuit setup
    • Gently twist and pull the used/contaminated bacterial filter from the inspiratory outlet.
    • Next, twist and pull the used/contaminated bacterial filter from the inspiratory limb.
    • The used/contaminated bacterial filter should now be removed from the inspiratory port.
    • In reassembly, a new/non-contaminated INSPIRATORY bacterial filter will be used for this step. In addition, use a twist and pushing motion instead.
  3. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): stap 3, afbeelding 1 van 1
    • Disconnect used/contaminated EXPIRATORY bacterial filter from circuit setup
    • Gently twist and pull the used/contaminated bacterial filter from the expiratory outlet.
    • Next, twist and pull the used/contaminated bacterial filter from the expiratory limb.
    • The used/contaminated bacterial filter should now be removed from the expiratory port.
    • In reassembly, a new/non-contaminated EXPIRATORY bacterial filter will be used for this step. In addition, use a twist and pushing motion instead.
  4. HAMILTON C-1 Bacterial Filter Replacement (Dual Limb Circuit Setup): stap 4, afbeelding 1 van 1
    • Your two new bacterial filters should now be installed in their respective inspiratory and expiratory ports.
    • After completing all steps, the end result should look like this:
Conclusie
Luisa Chiu
205 Reputatie
2 handleidingen geschreven
Cal Poly, Team S7-G11, Paton Spring 2020 Lid van Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 8
Altijd: 366
