Ga door naar hoofdinhoud
HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup)
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
  1. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup), Bacterial Filter: stap 1, afbeelding 1 van 1
    • Orient Hamilton-C1 so the right side of the device is facing you.
  2. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup): stap 2, afbeelding 1 van 1
    • Disconnect HME (heat and moisture exchanger) and flex tube
    • Bacterial filter is held within the HME.
    • Use both hands to gently pull and/or twist the flex tube and HME away from one another until fully disconnected.
    • The HME should still be connected to the overall circuit setup.
    • In reassembly, a new HME with a non-contaminated bacterial filter will be reconnected to the flex tube for this step.
  3. HAMILTON C-1 Bacterial Filter Replacement (Coaxial Circuit Setup): stap 3, afbeelding 1 van 1
    • Disconnect HME and circuit setup
    • Use both hands to gently pull and/or twist the flow sensor and HME away from one another until fully disconnected.
    • The HME (with used/contaminated bacterial filter) should now be completely disconnected from all parts.
    • In reassembly, a new HME with a non-contaminated bacterial filter will be reconnected to the flow sensor for this step.
Conclusie
Luisa Chiu
205 Reputatie
2 handleidingen geschreven
Cal Poly, Team S7-G11, Paton Spring 2020 Lid van Cal Poly, Team S7-G11, Paton Spring 2020
CPSU-PATON-S20S7G11
2 Leden
6 handleidingen geschreven
Één opmerking
Okay how offen should change out a carbon filter?
Bill Mcleod - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 711
