Ga door naar hoofdinhoud
Graco Secure Coverage LED Parent Unit Replacement
Wat je nodig hebt
  1. Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: stap 1, afbeelding 1 van 3 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: stap 1, afbeelding 2 van 3 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: stap 1, afbeelding 3 van 3
    • Using plastic opening tool, pry and remove the battery lid.
    Vraag FixBot
    Voeg opmerking toe
  2. Graco Secure Coverage LED Parent Unit Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: stap 3, afbeelding 1 van 2 Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: stap 3, afbeelding 2 van 2
    • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
    Vraag FixBot
    Voeg opmerking toe
  4. Graco Secure Coverage LED Parent Unit Replacement: stap 4, afbeelding 1 van 2 Graco Secure Coverage LED Parent Unit Replacement: stap 4, afbeelding 2 van 2
    • Using opening plastic tool, pry the two grey cases from both sides of the device.
    • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
    • While pry off the grey cases, hold the device with your other hand to remove the cases
    Vraag FixBot
    Voeg opmerking toe
  5. Graco Secure Coverage LED Parent Unit Replacement: stap 5, afbeelding 1 van 1
    • Pry the edges of the device to separate the front and rare cases.
    • While prying the edges, hold the device with one hand to pull out each case a part.
    • Make sure you use a constant force, and the pushbuttons are pried off completely.
    Vraag FixBot
    Voeg opmerking toe
  6. Graco Secure Coverage LED Parent Unit Replacement: stap 6, afbeelding 1 van 2 Graco Secure Coverage LED Parent Unit Replacement: stap 6, afbeelding 2 van 2
    • Remove the 7mm Phillips #1 screw from the mother board.
    • Place the screw in a secure place.
    Vraag FixBot
    Voeg opmerking toe
  7. Graco Secure Coverage LED Parent Unit Replacement: stap 7, afbeelding 1 van 2 Graco Secure Coverage LED Parent Unit Replacement: stap 7, afbeelding 2 van 2
    • Flip over the motherboard.
    • Solder off LED from motherboard.
    • There are many pins attached to the motherboard, make sure you solder off the proper pins that attached to the LED's.
    • Replace the LED's
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Bryson Wolff
237 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-5, Remmell Fall 2015 Lid van USF Tampa, Team 6-5, Remmell Fall 2015
USFT-REMMELL-F15S6G5
4 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 375
