Ga door naar hoofdinhoud
Google Pixel C Screen Replacement
Wat je nodig hebt
    1. Google Pixel C Screen Replacement, Screen: stap 1, afbeelding 1 van 1
      • Ensure that the device is completely powered down before beginning to take it apart
      • Use a heat gun to melt the adhesive that holds the screen to the device
      • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
      • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
      Vraag FixBot
      Voeg opmerking toe
    2. Google Pixel C Screen Replacement: stap 2, afbeelding 1 van 2 Google Pixel C Screen Replacement: stap 2, afbeelding 2 van 2
      • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
      • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
      • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
      • Reattaching the screen will require adhesive to ensure that it stays in place.
      Vraag FixBot
      Voeg opmerking toe
    3. Google Pixel C Screen Replacement: stap 3, afbeelding 1 van 2 Google Pixel C Screen Replacement: stap 3, afbeelding 2 van 2
      • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
      Vraag FixBot
      Voeg opmerking toe
    4. Google Pixel C Screen Replacement: stap 4, afbeelding 1 van 2 Google Pixel C Screen Replacement: stap 4, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Follow the same removal procedure to detach the wide gold cable.
      • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
      • This device is missing a battery, so the device that you are working on may appear slightly different inside.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Deborah Iwakiri
522 Reputatie
2 handleidingen geschreven
Cal Poly, Team S21-G4, Livingston Spring 2017 Lid van Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Leden
11 handleidingen geschreven
28Gids Commentaar
Where can a replacement screen be located?
Ronnie Williams - Antwoord Deel
Where can i buy a spare screen for this tablet?
Luigi Abbinante - Antwoord Deel
Yes, I have to buy the screen too, but where??
Кирилл Кнышев - Antwoord Deel
All very nice but unfortunately useless without knowing where to get the parts :(
Lorenzo Braschi - Antwoord Deel
Ciao Lorenzo, sei poi riuscito a trovare il ricambio?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 86
Altijd: 19,629
