Ga door naar hoofdinhoud
Google Pixel C Power Button Replacement
Wat je nodig hebt
    1. Google Pixel C Power Button Replacement, Screen: stap 1, afbeelding 1 van 1
      • Ensure that the device is completely powered down before beginning to take it apart
      • Use a heat gun to melt the adhesive that holds the screen to the device
      • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
      • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
      Vraag FixBot
      Voeg opmerking toe
    2. Google Pixel C Power Button Replacement: stap 2, afbeelding 1 van 2 Google Pixel C Power Button Replacement: stap 2, afbeelding 2 van 2
      • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
      • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
      • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
      • Reattaching the screen will require adhesive to ensure that it stays in place.
      Vraag FixBot
      Voeg opmerking toe
    3. Google Pixel C Power Button Replacement: stap 3, afbeelding 1 van 2 Google Pixel C Power Button Replacement: stap 3, afbeelding 2 van 2
      • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
      Vraag FixBot
      Voeg opmerking toe
    4. Google Pixel C Power Button Replacement: stap 4, afbeelding 1 van 2 Google Pixel C Power Button Replacement: stap 4, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Follow the same removal procedure to detach the wide gold cable.
      • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
      • This device is missing a battery, so the device that you are working on may appear slightly different inside.
      Vraag FixBot
      Voeg opmerking toe
    1. Google Pixel C Power Button Replacement, Power Button: stap 5, afbeelding 1 van 1
      • Locate the power button along the edge of the tablet.
      • The actual power button technology is the black plastic piece located directly inside the device behind the silver button; this is what will be replaced.
      Vraag FixBot
      Voeg opmerking toe
    2. Google Pixel C Power Button Replacement: stap 6, afbeelding 1 van 2 Google Pixel C Power Button Replacement: stap 6, afbeelding 2 van 2
      • Locate and remove the black 4.3mm Phillips #000 screw.
      • Remove the remaining two silver 4.2mm Phillips #000 screws.
      Vraag FixBot
      Voeg opmerking toe
    3. Google Pixel C Power Button Replacement: stap 7, afbeelding 1 van 2 Google Pixel C Power Button Replacement: stap 7, afbeelding 2 van 2
      • Use tweezers to slowly pull up on the power button technology as far as possible without pulling out the two black wires attached.
      • Don't pull up too hard, as the wires could be ripped out and damaged.
      Vraag FixBot
      Voeg opmerking toe
    4. Google Pixel C Power Button Replacement: stap 8, afbeelding 1 van 2 Google Pixel C Power Button Replacement: stap 8, afbeelding 2 van 2
      • Detach the larger connector wire by flipping the copper hinge located at the base of the connection with your fingernail.
      Vraag FixBot
      Voeg opmerking toe
    5. Google Pixel C Power Button Replacement: stap 9, afbeelding 1 van 1
      • Flip the hinge of the second, more narrow wire to release the connection.
      • Don't pull the power button technology out yet. This wire is attached at one more place in the device.
      Vraag FixBot
      Voeg opmerking toe
    6. Google Pixel C Power Button Replacement: stap 10, afbeelding 1 van 2 Google Pixel C Power Button Replacement: stap 10, afbeelding 2 van 2
      • Locate and remove the three 4.2mm Phillips #000 screws at the base of where the second wire is still connected.
      Vraag FixBot
      Voeg opmerking toe
    7. Google Pixel C Power Button Replacement: stap 11, afbeelding 1 van 2 Google Pixel C Power Button Replacement: stap 11, afbeelding 2 van 2
      • Once all the screws are removed, gently pull up on the entire power button technology piece, to remove it from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. New adhesive will be needed to re-apply the screen.
Één andere persoon heeft deze handleiding voltooid.
Isabelle Tang
225 Reputatie
2 handleidingen geschreven
Cal Poly, Team S21-G4, Livingston Spring 2017 Lid van Cal Poly, Team S21-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G4
4 Leden
11 handleidingen geschreven
1Gids Commentaar
I have replaced the power/volume button flex with these instructions with a reportably working item, but power button still doesn't work. The volume buttons work just fine. Any other ideas about what might be the problem?
Colleen Price - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 51
Altijd: 3,161
