Ga door naar hoofdinhoud
Google Cr-48 Chromebook Bottom Casing Replacement
Wat je nodig hebt
    1. Google Cr-48 Chromebook Bottom Casing Replacement, Battery: stap 1, afbeelding 1 van 3 Google Cr-48 Chromebook Bottom Casing Replacement, Battery: stap 1, afbeelding 2 van 3 Google Cr-48 Chromebook Bottom Casing Replacement, Battery: stap 1, afbeelding 3 van 3
      • To take out the battery, slide the switch on the bottom of the laptop.
      • The battery should then pop out and you can remove it.
      Vraag FixBot
      Voeg opmerking toe
    1. Google Cr-48 Chromebook Bottom Casing Replacement, Bottom Casing: stap 2, afbeelding 1 van 2 Google Cr-48 Chromebook Bottom Casing Replacement, Bottom Casing: stap 2, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
      Vraag FixBot
      Voeg opmerking toe
    2. Google Cr-48 Chromebook Bottom Casing Replacement: stap 3, afbeelding 1 van 3 Google Cr-48 Chromebook Bottom Casing Replacement: stap 3, afbeelding 2 van 3 Google Cr-48 Chromebook Bottom Casing Replacement: stap 3, afbeelding 3 van 3
      • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
      • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
      Vraag FixBot
      Voeg opmerking toe
    3. Google Cr-48 Chromebook Bottom Casing Replacement: stap 4, afbeelding 1 van 3 Google Cr-48 Chromebook Bottom Casing Replacement: stap 4, afbeelding 2 van 3 Google Cr-48 Chromebook Bottom Casing Replacement: stap 4, afbeelding 3 van 3
      • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
      • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Robert McLaughlin
471 Reputatie
3 handleidingen geschreven
CSU Fullerton, Team 2-2, Bruce Fall 2014 Lid van CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Leden
35 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 1,191
