Ga door naar hoofdinhoud
GoPro Karma Propeller Replacement
    1. GoPro Karma Propeller Replacement, Battery: stap 1, afbeelding 1 van 1
      • Hook your fingers on the tab and pull out the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. GoPro Karma Propeller Replacement, Stabilizer: stap 2, afbeelding 1 van 3 GoPro Karma Propeller Replacement, Stabilizer: stap 2, afbeelding 2 van 3 GoPro Karma Propeller Replacement, Stabilizer: stap 2, afbeelding 3 van 3
      • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
      • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
      Vraag FixBot
      Voeg opmerking toe
    2. GoPro Karma Propeller Replacement: stap 3, afbeelding 1 van 1
      • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
      Vraag FixBot
      Voeg opmerking toe
    1. GoPro Karma Propeller Replacement, Propeller: stap 4, afbeelding 1 van 3 GoPro Karma Propeller Replacement, Propeller: stap 4, afbeelding 2 van 3 GoPro Karma Propeller Replacement, Propeller: stap 4, afbeelding 3 van 3
      • Extend the arms and set the drone face up.
      • The front right and back left propellers unscrew clockwise.
      • The front left and back right propellers unscrew counterclockwise.
      Vraag FixBot
      Voeg opmerking toe
    2. GoPro Karma Propeller Replacement: stap 5, afbeelding 1 van 2 GoPro Karma Propeller Replacement: stap 5, afbeelding 2 van 2
      • Place the GoPro Karma wrench on the motor.
      • Hold the motor in place with the wrench and unscrew the propeller in the indicated direction.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jay Ingram
334 Reputatie
3 handleidingen geschreven
Cal Poly, Team S25-G14, Maness Spring 2018 Lid van Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Leden
6 handleidingen geschreven
2Gids Commentaar
You got it the wrong way around, to take them off you need to do the exact opposite to what you say.
michael.woelk - Antwoord Deel
hi, i am trying to fix my Karma. I have to remove the propellers but it is like they are stocked.
I try to unscrew the propellers but i can’t remove them.
Do you know what to do in this case?
Davide Negro - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 34
Altijd: 2,178
