Ga door naar hoofdinhoud
GoPro Hero5 Black Lens Assembly Replacement
Wat je nodig hebt
  1. GoPro Hero5 Black Lens Assembly Replacement, Battery: stap 1, afbeelding 1 van 3 GoPro Hero5 Black Lens Assembly Replacement, Battery: stap 1, afbeelding 2 van 3 GoPro Hero5 Black Lens Assembly Replacement, Battery: stap 1, afbeelding 3 van 3
    • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
    Vraag FixBot
    Voeg opmerking toe
  2. GoPro Hero5 Black Lens Assembly Replacement: stap 2, afbeelding 1 van 3 GoPro Hero5 Black Lens Assembly Replacement: stap 2, afbeelding 2 van 3 GoPro Hero5 Black Lens Assembly Replacement: stap 2, afbeelding 3 van 3
    • Grab the plastic flap on the battery and pull the battery out.
    Vraag FixBot
    Voeg opmerking toe
  3. GoPro Hero5 Black Lens Assembly Replacement, Back Housing: stap 3, afbeelding 1 van 2 GoPro Hero5 Black Lens Assembly Replacement, Back Housing: stap 3, afbeelding 2 van 2
    • Pull and twist the lens cover right or left until it pops off.
    • The lens cover is secured tightly and might be difficult to twist off.
    Vraag FixBot
    Voeg opmerking toe
  4. GoPro Hero5 Black Lens Assembly Replacement: stap 4, afbeelding 1 van 1
    • This step is not necessary but will make the process of removing the faceplate much easier.
    • Refer to the iOpener instructions for how to heat up and use the iOpener.
    • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
    • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
    Vraag FixBot
    Voeg opmerking toe
  5. GoPro Hero5 Black Lens Assembly Replacement: stap 5, afbeelding 1 van 3 GoPro Hero5 Black Lens Assembly Replacement: stap 5, afbeelding 2 van 3 GoPro Hero5 Black Lens Assembly Replacement: stap 5, afbeelding 3 van 3
    • Starting with the edges, use the spudger to pry off the faceplate.
    • The faceplate is held down with adhesive and may take a while to get off.
    Vraag FixBot
    Voeg opmerking toe
  6. GoPro Hero5 Black Lens Assembly Replacement: stap 6, afbeelding 1 van 2 GoPro Hero5 Black Lens Assembly Replacement: stap 6, afbeelding 2 van 2
    • Remove the six T3 Torx screws.
    Vraag FixBot
    Voeg opmerking toe
  7. GoPro Hero5 Black Lens Assembly Replacement: stap 7, afbeelding 1 van 3 GoPro Hero5 Black Lens Assembly Replacement: stap 7, afbeelding 2 van 3 GoPro Hero5 Black Lens Assembly Replacement: stap 7, afbeelding 3 van 3
    • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
    • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
    Vraag FixBot
    Voeg opmerking toe
  8. GoPro Hero5 Black Lens Assembly Replacement: stap 8, afbeelding 1 van 3 GoPro Hero5 Black Lens Assembly Replacement: stap 8, afbeelding 2 van 3 GoPro Hero5 Black Lens Assembly Replacement: stap 8, afbeelding 3 van 3
    • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  9. GoPro Hero5 Black Lens Assembly Replacement: stap 9, afbeelding 1 van 2 GoPro Hero5 Black Lens Assembly Replacement: stap 9, afbeelding 2 van 2
    • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  10. GoPro Hero5 Black Lens Assembly Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Use the flat end of the spudger to pry the black cover plate straight up from its socket on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  11. GoPro Hero5 Black Lens Assembly Replacement: stap 11, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use the tweezers to pull the ribbon cable connector out of its white socket on the charging assembly board.
    Vraag FixBot
    Voeg opmerking toe
  12. GoPro Hero5 Black Lens Assembly Replacement: stap 12, afbeelding 1 van 2 GoPro Hero5 Black Lens Assembly Replacement: stap 12, afbeelding 2 van 2
    • Remove the two #000 Phillips screw.
    Vraag FixBot
    Voeg opmerking toe
  13. GoPro Hero5 Black Lens Assembly Replacement: stap 13, afbeelding 1 van 2 GoPro Hero5 Black Lens Assembly Replacement: stap 13, afbeelding 2 van 2
    • Use the flat end of the spudger to pry the charging port ribbon cable connector straight up from its socket on the motherboard.
    • Once the ribbon cable is disconnected from the motherboard. The charging port assembly should come right off.
    Vraag FixBot
    Voeg opmerking toe
  14. GoPro Hero5 Black Lens Assembly Replacement: stap 14, afbeelding 1 van 2 GoPro Hero5 Black Lens Assembly Replacement: stap 14, afbeelding 2 van 2
    • Remove the 10mm #000 Phillips screw.
    Vraag FixBot
    Voeg opmerking toe
  15. GoPro Hero5 Black Lens Assembly Replacement: stap 15, afbeelding 1 van 1
    • Remove the charging assembly housing by pulling it straight up off the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  16. GoPro Hero5 Black Lens Assembly Replacement: stap 16, afbeelding 1 van 2 GoPro Hero5 Black Lens Assembly Replacement: stap 16, afbeelding 2 van 2
    • Remove the two 6mm #000 Phillips screws.
    • Remove the two 2mm #000 Phillips screws.
    Vraag FixBot
    Voeg opmerking toe
  17. GoPro Hero5 Black Lens Assembly Replacement: stap 17, afbeelding 1 van 1
    • Use the flat end of the spudger to pry the lens assembly ribbon cable connector straight up from its socket on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  18. GoPro Hero5 Black Lens Assembly Replacement: stap 18, afbeelding 1 van 1
    • Use the flat end of the spudger to pry the LCD screen ribbon cable connector straight up from its socket on the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  19. GoPro Hero5 Black Lens Assembly Replacement: stap 19, afbeelding 1 van 3 GoPro Hero5 Black Lens Assembly Replacement: stap 19, afbeelding 2 van 3 GoPro Hero5 Black Lens Assembly Replacement: stap 19, afbeelding 3 van 3
    • Use the flat end of the spudger to pry the motherboard off the midframe.
    • The motherboard is held onto the midframe with light adhesive and should come right off with a little force.
    Vraag FixBot
    Voeg opmerking toe
  20. GoPro Hero5 Black Lens Assembly Replacement, Lens Assembly: stap 20, afbeelding 1 van 2 GoPro Hero5 Black Lens Assembly Replacement, Lens Assembly: stap 20, afbeelding 2 van 2
    • Remove the 2mm #000 Phillips screws using a #000 Phillips head screwdriver or tool bit.
    Vraag FixBot
    Voeg opmerking toe
  21. GoPro Hero5 Black Lens Assembly Replacement: stap 21, afbeelding 1 van 2 GoPro Hero5 Black Lens Assembly Replacement: stap 21, afbeelding 2 van 2
    • Pull the lens assembly straight out from the Midframe.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
16 andere personen hebben deze handleiding voltooid.
Christopher Adams
2.133 Reputatie
5 handleidingen geschreven
Cal Poly, Team 18-6, Forte Fall 2016 Lid van Cal Poly, Team 18-6, Forte Fall 2016
CPSU-FORTE-F16S18G6
4 Leden
22 handleidingen geschreven
7Gids Commentaar
RageCams has interchangeable lens mod for hero5
http://ragecams.com/shop/modified-gopro-...
dennis - Antwoord Deel
why can't You show how the lens is mount to that assembly? That's the point of it... can we change lenses that way or not?
Polina Luzenco - Antwoord Deel
Exactly. Can the actual lens be unscrewed from the mount or it glued / fixed?
contact - Antwoord Deel
The lens is heavily glued onto the assembly. It would be far easier to replace the entire assembly than trying to remove that glue.
Christopher Adams - Antwoord Deel
the guy who wrote the guide apparently has never heard of pliers. it comes right out, but no idea what the threading is.
mattatron4 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 68
Altijd: 17,869
