Ga door naar hoofdinhoud
GoPro Hero4 Silver Front Panel Replacement
Wat je nodig hebt
    1. GoPro Hero4 Silver Front Panel Replacement, Front Panel: stap 1, afbeelding 1 van 3 GoPro Hero4 Silver Front Panel Replacement, Front Panel: stap 1, afbeelding 2 van 3 GoPro Hero4 Silver Front Panel Replacement, Front Panel: stap 1, afbeelding 3 van 3
      • Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on.
      • The seven plastic tab locations are marked in red.
      • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the camera face off, but found that it did not give us enough leverage.
      • There may be glue holding the camera face on to the housing. Be careful not to flex the camera face too much, or it will crack.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
15 andere personen hebben deze handleiding voltooid.
Zack Hoover
1.109 Reputatie
3 handleidingen geschreven
USF Tampa, Team 2-1, Blackwell Fall 2015 Lid van USF Tampa, Team 2-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G1
4 Leden
54 handleidingen geschreven
2Gids Commentaar
Am I mistaken, or are there missing steps in this guide?
Tom Fox - Antwoord Deel
Looks like a simple remove/replace guide. Only one step needed.
justincarver - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 59
Altijd: 12,788
