Ga door naar hoofdinhoud
GoPro Hero Lens Replacement
Wat je nodig hebt
  1. GoPro Hero Lens Replacement, Casing: stap 1, afbeelding 1 van 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
    Vraag FixBot
    Voeg opmerking toe
  2. GoPro Hero Lens Replacement: stap 2, afbeelding 1 van 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
    Vraag FixBot
    Voeg opmerking toe
  3. GoPro Hero Lens Replacement: stap 3, afbeelding 1 van 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    Vraag FixBot
    Voeg opmerking toe
  4. GoPro Hero Lens Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
    Vraag FixBot
    Voeg opmerking toe
  5. GoPro Hero Lens Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
    Vraag FixBot
    Voeg opmerking toe
  6. GoPro Hero Lens Replacement: stap 6, afbeelding 1 van 1
    • Carefully remove the motherboard and white plastic piece from the case.
    Vraag FixBot
    Voeg opmerking toe
  7. GoPro Hero Lens Replacement, Lens: stap 7, afbeelding 1 van 1
    • Remove the four screws from the lens.
    • These screws are smaller than the ones removed from the white plastic piece.
    Vraag FixBot
    Voeg opmerking toe
  8. GoPro Hero Lens Replacement: stap 8, afbeelding 1 van 1
    • Remove the lens from the case.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow the instructions in reverse order.
3 andere personen hebben deze handleiding voltooid.
River Drake
1.065 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-2, Lancaster Spring 2015 Lid van Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Leden
18 handleidingen geschreven
1Gids Commentaar
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
Doggo Boi - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 71
Altijd: 14,149
