Ga door naar hoofdinhoud
GoPro Hero LCD Screen Replacement
Wat je nodig hebt
    1. GoPro Hero LCD Screen Replacement, Casing: stap 1, afbeelding 1 van 1
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      Vraag FixBot
      Voeg opmerking toe
    2. GoPro Hero LCD Screen Replacement: stap 2, afbeelding 1 van 1
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      Vraag FixBot
      Voeg opmerking toe
    3. GoPro Hero LCD Screen Replacement: stap 3, afbeelding 1 van 1
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      Vraag FixBot
      Voeg opmerking toe
    4. GoPro Hero LCD Screen Replacement: stap 4, afbeelding 1 van 1
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      Vraag FixBot
      Voeg opmerking toe
    5. GoPro Hero LCD Screen Replacement: stap 5, afbeelding 1 van 1
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      Vraag FixBot
      Voeg opmerking toe
    6. GoPro Hero LCD Screen Replacement: stap 6, afbeelding 1 van 1
      • Carefully remove the motherboard and white plastic piece from the case.
      Vraag FixBot
      Voeg opmerking toe
    1. GoPro Hero LCD Screen Replacement, LCD Screen: stap 7, afbeelding 1 van 2 GoPro Hero LCD Screen Replacement, LCD Screen: stap 7, afbeelding 2 van 2
      • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
      • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
      Vraag FixBot
      Voeg opmerking toe
    2. GoPro Hero LCD Screen Replacement: stap 8, afbeelding 1 van 1
      • Separate the motherboard from the white piece of plastic.
      Vraag FixBot
      Voeg opmerking toe
    3. GoPro Hero LCD Screen Replacement: stap 9, afbeelding 1 van 1
      • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
      Vraag FixBot
      Voeg opmerking toe
    4. GoPro Hero LCD Screen Replacement: stap 10, afbeelding 1 van 2 GoPro Hero LCD Screen Replacement: stap 10, afbeelding 2 van 2
      • Separate the LCD screen from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
River Drake
1.065 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-2, Lancaster Spring 2015 Lid van Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Leden
30 handleidingen geschreven
3Gids Commentaar
Where do you buy the replacement lcd
Anthony Volatile - Antwoord Deel
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
Addisen KING - Antwoord Deel
I can find the screen but is it compatible with the Hero+
Brian Casado - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 172
Altijd: 27,449
