Ga door naar hoofdinhoud
GoPro Hero Battery Replacement
Wat je nodig hebt
    1. GoPro Hero Battery Replacement, Battery: stap 1, afbeelding 1 van 1
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      Vraag FixBot
      Voeg opmerking toe
    2. GoPro Hero Battery Replacement: stap 2, afbeelding 1 van 1
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      Vraag FixBot
      Voeg opmerking toe
    3. GoPro Hero Battery Replacement: stap 3, afbeelding 1 van 1
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      • Use a plastic spudger to pry the battery off from the white plastic piece underneath.
      • The battery is glued to the plastic so some force might be necessary.
      • Be careful not to damage the battery to avoid releasing dangerous chemicals.
      Vraag FixBot
      Voeg opmerking toe
    4. GoPro Hero Battery Replacement: stap 4, afbeelding 1 van 1
      • Remove the battery from the GoPro.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
29 andere personen hebben deze handleiding voltooid.
River Drake
1.065 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-2, Lancaster Spring 2015 Lid van Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Leden
18 handleidingen geschreven
20Gids Commentaar
The tutorial is excellent, even with a link to the tools needed, but no link to battery sale.
Could you please include this?
juliomap - Antwoord Deel
Very good tutorial thank you. But I can also find no place to buy a new battery... But here is a petition to make Gopro sell spare parts: https://www.change.org/p/gopro-support-o...
maire - Antwoord Deel
I followed these steps and inadvertently pulled not only the battery plug but its adapter (housing) at the same time. Now I can't plug the battery back in because there's no place to plug it! Contacting GoPro they stressed that the battery is not intended for removal.
erikwikstrom - Antwoord Deel
Awesome! Could you also show us how to put in a new battery, how do i prep my battery? What type of a battery can i use ? Thanks a lot !!
John misquita - Antwoord Deel
now add go pro to rice for a day and pray.
chadd23 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 57
Afgelopen 30 dagen: 253
Altijd: 84,069
