Ga door naar hoofdinhoud
GoPro Hero 3 Silver Rear Housing Replacement
Wat je nodig hebt
    1. GoPro Hero 3 Silver Rear Housing Replacement, Battery: stap 1, afbeelding 1 van 2 GoPro Hero 3 Silver Rear Housing Replacement, Battery: stap 1, afbeelding 2 van 2
      • Pull back on the tab on the back of GoPro to open the battery cover.
      Vraag FixBot
      Voeg opmerking toe
    2. GoPro Hero 3 Silver Rear Housing Replacement: stap 2, afbeelding 1 van 1
      • Pull the battery out using the tab.
      Vraag FixBot
      Voeg opmerking toe
    1. GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: stap 3, afbeelding 1 van 2 GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: stap 3, afbeelding 2 van 2
      • Use the plastic opening tool to remove the faceplate.
      • There is some adhesive and clips so be careful and the faceplate should pop right off.
      Vraag FixBot
      Voeg opmerking toe
    2. GoPro Hero 3 Silver Rear Housing Replacement: stap 4, afbeelding 1 van 2 GoPro Hero 3 Silver Rear Housing Replacement: stap 4, afbeelding 2 van 2
      • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
      • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
      Vraag FixBot
      Voeg opmerking toe
    3. GoPro Hero 3 Silver Rear Housing Replacement: stap 5, afbeelding 1 van 2 GoPro Hero 3 Silver Rear Housing Replacement: stap 5, afbeelding 2 van 2
      • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
      • Using the plastic opening tool, slowly pry open the motherboard assembly.
      Vraag FixBot
      Voeg opmerking toe
    4. GoPro Hero 3 Silver Rear Housing Replacement: stap 6, afbeelding 1 van 2 GoPro Hero 3 Silver Rear Housing Replacement: stap 6, afbeelding 2 van 2
      • Use the spudger to gently pry off the connector of the housing to the motherboard.
      • You should now have the motherboard assembly and the housing separated.
      Vraag FixBot
      Voeg opmerking toe
    5. GoPro Hero 3 Silver Rear Housing Replacement: stap 7, afbeelding 1 van 1
      • In order to replace the buttons. The entire housing has to be replaced.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brian Alvarez
1.439 Reputatie
6 handleidingen geschreven
Cal Poly, Team 24-7, Lancaster Spring 2015 Lid van Cal Poly, Team 24-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G7
3 Leden
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 2,873
