Ga door naar hoofdinhoud
GoPro Hero 3+ Silver Edition Motherboard Replacement
Wat je nodig hebt
  1. GoPro Hero 3+ Silver Edition Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 GoPro Hero 3+ Silver Edition Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Push the tab on the back of the device left to remove the plate covering the battery.
  2. GoPro Hero 3+ Silver Edition Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Use the strip of tape on the battery to remove the battery from the housing.
  3. GoPro Hero 3+ Silver Edition Motherboard Replacement, Front Panel: stap 3, afbeelding 1 van 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  4. GoPro Hero 3+ Silver Edition Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
  5. GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: stap 5, afbeelding 1 van 3 GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: stap 5, afbeelding 2 van 3 GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: stap 5, afbeelding 3 van 3
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
  6. GoPro Hero 3+ Silver Edition Motherboard Replacement: stap 6, afbeelding 1 van 2 GoPro Hero 3+ Silver Edition Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
  7. GoPro Hero 3+ Silver Edition Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
  8. GoPro Hero 3+ Silver Edition Motherboard Replacement: stap 8, afbeelding 1 van 2 GoPro Hero 3+ Silver Edition Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
  9. GoPro Hero 3+ Silver Edition Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 1
    • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
  10. GoPro Hero 3+ Silver Edition Motherboard Replacement: stap 10, afbeelding 1 van 3 GoPro Hero 3+ Silver Edition Motherboard Replacement: stap 10, afbeelding 2 van 3 GoPro Hero 3+ Silver Edition Motherboard Replacement: stap 10, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
    • Gently remove the motherboard from the midframe using tweezers.
    • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Blake Ehlers
668 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-8, Maness Fall 2015 Lid van Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Leden
12 handleidingen geschreven
2Gids Commentaar
hi, where i can find the matherboard for de hero 3+ silver?
Mauricio - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 3,861
