Inleiding
Use this guide to replace the microSD/Micro USB port assembly in your GoPro Hero+ LCD.
Wat je nodig hebt
Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
Remove the two 6 mm Phillips #00 screws.
Remove the single 4 mm Phillips #000 screws.
5 andere personen hebben deze handleiding voltooid.
