Ga door naar hoofdinhoud
GoPro Hero+ LCD Lens Replacement
Wat je nodig hebt
  1. GoPro Hero+ LCD Lens Replacement, Back Panel: stap 1, afbeelding 1 van 2 GoPro Hero+ LCD Lens Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
    Vraag FixBot
    Voeg opmerking toe
  2. GoPro Hero+ LCD Lens Replacement: stap 2, afbeelding 1 van 2 GoPro Hero+ LCD Lens Replacement: stap 2, afbeelding 2 van 2
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
    Vraag FixBot
    Voeg opmerking toe
  3. GoPro Hero+ LCD Lens Replacement: stap 3, afbeelding 1 van 2 GoPro Hero+ LCD Lens Replacement: stap 3, afbeelding 2 van 2
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
    Vraag FixBot
    Voeg opmerking toe
  4. GoPro Hero+ LCD Lens Replacement, Battery: stap 4, afbeelding 1 van 1
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
    Vraag FixBot
    Voeg opmerking toe
  5. GoPro Hero+ LCD Lens Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Using tweezers, peel off the copper tape on the right side of the battery.
    Vraag FixBot
    Voeg opmerking toe
  6. GoPro Hero+ LCD Lens Replacement: stap 6, afbeelding 1 van 2 GoPro Hero+ LCD Lens Replacement: stap 6, afbeelding 2 van 2
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
    Vraag FixBot
    Voeg opmerking toe
  7. GoPro Hero+ LCD Lens Replacement: stap 7, afbeelding 1 van 1
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
    Vraag FixBot
    Voeg opmerking toe
  8. GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: stap 8, afbeelding 1 van 3 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: stap 8, afbeelding 2 van 3 GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: stap 8, afbeelding 3 van 3
    • Remove the two 6 mm Phillips #00 screws.
    • Remove the single 4 mm Phillips #000 screws.
    Vraag FixBot
    Voeg opmerking toe
  9. GoPro Hero+ LCD Lens Replacement: stap 9, afbeelding 1 van 1
    • Remove the image sensor from the camera.
    • You do not have to unplug the black box to remove the USB/SD chip.
    Vraag FixBot
    Voeg opmerking toe
  10. GoPro Hero+ LCD Lens Replacement: stap 10, afbeelding 1 van 1
    • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
    • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
    Vraag FixBot
    Voeg opmerking toe
  11. GoPro Hero+ LCD Lens Replacement: stap 11, afbeelding 1 van 1
    • Gently lift the microSD/Micro USB assembly up and out of the device.
    Vraag FixBot
    Voeg opmerking toe
  12. GoPro Hero+ LCD Lens Replacement, Image Sensor: stap 12, afbeelding 1 van 1
    • Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
    • Do not yank on the image sensor, it can rip out the wiring or damage the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  13. GoPro Hero+ LCD Lens Replacement, Motherboard: stap 13, afbeelding 1 van 3 GoPro Hero+ LCD Lens Replacement, Motherboard: stap 13, afbeelding 2 van 3 GoPro Hero+ LCD Lens Replacement, Motherboard: stap 13, afbeelding 3 van 3
    • Remove the three 4 mm Phillips #000 screws securing the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  14. GoPro Hero+ LCD Lens Replacement: stap 14, afbeelding 1 van 1
    • Use your fingers to gently remove the ribbon connected to the lens.
    • Be careful when removing the ribbon cable. Pull off gently or you can separate the ribbon from the contacts.
    Vraag FixBot
    Voeg opmerking toe
  15. GoPro Hero+ LCD Lens Replacement: stap 15, afbeelding 1 van 3 GoPro Hero+ LCD Lens Replacement: stap 15, afbeelding 2 van 3 GoPro Hero+ LCD Lens Replacement: stap 15, afbeelding 3 van 3
    • Use your fingers and carefully pull out the motherboard from under the lens. It may take a little bit of adjusting to get it out.
    Vraag FixBot
    Voeg opmerking toe
  16. GoPro Hero+ LCD Lens Replacement, Lens: stap 16, afbeelding 1 van 3 GoPro Hero+ LCD Lens Replacement, Lens: stap 16, afbeelding 2 van 3 GoPro Hero+ LCD Lens Replacement, Lens: stap 16, afbeelding 3 van 3
    • Remove the two 4 mm Phillips #000 screws securing the top button.
    Vraag FixBot
    Voeg opmerking toe
  17. GoPro Hero+ LCD Lens Replacement: stap 17, afbeelding 1 van 2 GoPro Hero+ LCD Lens Replacement: stap 17, afbeelding 2 van 2
    • Remove the four 4 mm Phillips #000 screws securing the lens to the case.
    Vraag FixBot
    Voeg opmerking toe
  18. GoPro Hero+ LCD Lens Replacement: stap 18, afbeelding 1 van 3 GoPro Hero+ LCD Lens Replacement: stap 18, afbeelding 2 van 3 GoPro Hero+ LCD Lens Replacement: stap 18, afbeelding 3 van 3
    • Gently lift the lens up and out of the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Matthew Tinkey
922 Reputatie
4 handleidingen geschreven
USF Tampa, Team 2-4, Blackwell Fall 2015 Lid van USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Leden
20 handleidingen geschreven
2Gids Commentaar
I'm curious if you have any suggestions for sourcing the replacement part.
Driftless Repair - Antwoord Deel
My hing clip is broken, Can I remove the actual camera & replace the full waterproof case then reinstall my camera into the new replacement case ?
jimmac044 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 47
Altijd: 7,346
