Inleiding
To remove the lens assembly, you must remove some internal parts first. Some of these screws are in tight places, so they will be tedious to access.
Wat je nodig hebt
Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
Remove the two 6 mm Phillips #00 screws.
Remove the single 4 mm Phillips #000 screws.
Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
