Ga door naar hoofdinhoud
GoPro Hero+ LCD Battery Replacement
Wat je nodig hebt
    1. GoPro Hero+ LCD Battery Replacement, Back Panel: stap 1, afbeelding 1 van 2 GoPro Hero+ LCD Battery Replacement, Back Panel: stap 1, afbeelding 2 van 2
      • Be sure to power off the GoPro before you start disassembly.
      • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
      Vraag FixBot
      Voeg opmerking toe
    2. GoPro Hero+ LCD Battery Replacement: stap 2, afbeelding 1 van 2 GoPro Hero+ LCD Battery Replacement: stap 2, afbeelding 2 van 2
      • Use the metal spudger to pry around the perimeter of the panel.
      • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
      Vraag FixBot
      Voeg opmerking toe
    3. GoPro Hero+ LCD Battery Replacement: stap 3, afbeelding 1 van 2 GoPro Hero+ LCD Battery Replacement: stap 3, afbeelding 2 van 2
      • Pry around the panel to ensure it is not attached to the device.
      • Move the panel to the side so you can access the internal components.
      • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
      Vraag FixBot
      Voeg opmerking toe
    1. GoPro Hero+ LCD Battery Replacement, Battery: stap 4, afbeelding 1 van 1
      • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
      • Be careful of metal contacts on strip; they can be sharp.
      Vraag FixBot
      Voeg opmerking toe
    2. GoPro Hero+ LCD Battery Replacement: stap 5, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Using tweezers, peel off the copper tape on the right side of the battery.
      Vraag FixBot
      Voeg opmerking toe
    3. GoPro Hero+ LCD Battery Replacement: stap 6, afbeelding 1 van 2 GoPro Hero+ LCD Battery Replacement: stap 6, afbeelding 2 van 2
      • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
      Vraag FixBot
      Voeg opmerking toe
    4. GoPro Hero+ LCD Battery Replacement: stap 7, afbeelding 1 van 1
      • Use a pair of tweezers to disconnect the battery connector from the motherboard.
      • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
19 andere personen hebben deze handleiding voltooid.
Kyle
219 Reputatie
1 Handleiding geschreven
USF Tampa, Team 2-4, Blackwell Fall 2015 Lid van USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Leden
20 handleidingen geschreven
13Gids Commentaar
This is a superb guide but where can one buy a replacement battery? I have looked on the web for the one in your photo but can't find a specific one.
I want to buy one of these cameras but would like to know I can replace the battery.
Thanks.
Andrew - Antwoord Deel
I am also trying to find the replacement battery for a Hero+. Have found a lot of batteries for all other versions of Gopro cams, but not one single one for a Hero+.
I have also sent an email to Gopro to get help. I am not prepared for an answer but I really would like to get hold of a battery.
Does anyone know how to get one?
Please contact me: rhafsrhafs@gmail.com. Rikard from Sweden.
Thanks
Rikard
Rikard Hård - Antwoord Deel
hi, do you know where i can get the housing for the gopro hero+ lcd. mine is broken and need a new one but can't find it anywhere...........
chris
christianrisan - Antwoord Deel
not even amazon?
Mary D'Alesandro - Antwoord Deel
this is awesome thanks a lot! , i dont want to be rude, but the title says battery replacementnt , why isnt anyone preparing a battery and putting it back in?, All everyone is doing is taking th battery out
John misquita - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 37
Afgelopen 30 dagen: 242
Altijd: 42,476
