Ga door naar hoofdinhoud
Giant Reign 2 Wheel Spoke Replacement
Wat je nodig hebt
    1. Giant Reign 2 Wheel Spoke Replacement, Hex Screws: stap 1, afbeelding 1 van 1
      • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
      Vraag FixBot
      Voeg opmerking toe
    2. Giant Reign 2 Wheel Spoke Replacement, Axle Screw: stap 2, afbeelding 1 van 2 Giant Reign 2 Wheel Spoke Replacement, Axle Screw: stap 2, afbeelding 2 van 2
      • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
      • Push the axle screw to reveal the axle rod on the other side.
      Vraag FixBot
      Voeg opmerking toe
    3. Giant Reign 2 Wheel Spoke Replacement: stap 3, afbeelding 1 van 1
      • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
      • Hold the wheel when pulling out the axle rod so that the bike does not fall.
      Vraag FixBot
      Voeg opmerking toe
    4. Giant Reign 2 Wheel Spoke Replacement, Front Wheel: stap 4, afbeelding 1 van 1
      • Pull the wheel from the fork.
      Vraag FixBot
      Voeg opmerking toe
    1. Giant Reign 2 Wheel Spoke Replacement, Tire Valve: stap 5, afbeelding 1 van 3 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: stap 5, afbeelding 2 van 3 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: stap 5, afbeelding 3 van 3
      • Twist and pull off the cap covering the tire valve
      • Twist off the spacer that holds the valve in place.
      • Push valve in toward wheel to release air pressure.
      Vraag FixBot
      Voeg opmerking toe
    2. Giant Reign 2 Wheel Spoke Replacement, Tire Rim: stap 6, afbeelding 1 van 3 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: stap 6, afbeelding 2 van 3 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: stap 6, afbeelding 3 van 3
      • Insert one tire lever between the tire and the rim.
      • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
      • Insert a second tire lever next to the first.
      • Slowly slide one tire lever around the rim until the tire is released from the rim.
      Vraag FixBot
      Voeg opmerking toe
    3. Giant Reign 2 Wheel Spoke Replacement, Tire Tube: stap 7, afbeelding 1 van 1
      • Using your hand, pull the tube completely out of the tire.
      Vraag FixBot
      Voeg opmerking toe
    4. Giant Reign 2 Wheel Spoke Replacement, Brake Rotor: stap 8, afbeelding 1 van 1
      • Use an 8mm Allen wrench to unscrew the 6 (4x10mm) screws on the brake rotor.
      • Pull brake rotors off both sides of the wheel.
      Vraag FixBot
      Voeg opmerking toe
    5. Giant Reign 2 Wheel Spoke Replacement, Tire: stap 9, afbeelding 1 van 1
      • Pull the tire from the rim.
      Vraag FixBot
      Voeg opmerking toe
    6. Giant Reign 2 Wheel Spoke Replacement, Rim Tape: stap 10, afbeelding 1 van 1
      • Using a tire lever, push the rim tape aside to reveal the spoke nipple.
      • Using your fingers, pull off the old spoke nipple.
      Vraag FixBot
      Voeg opmerking toe
    7. Giant Reign 2 Wheel Spoke Replacement, Wheel Spoke: stap 11, afbeelding 1 van 1
      • Push out the old spoke from the hub.
      Vraag FixBot
      Voeg opmerking toe
    8. Giant Reign 2 Wheel Spoke Replacement: stap 12, afbeelding 1 van 2 Giant Reign 2 Wheel Spoke Replacement: stap 12, afbeelding 2 van 2
      • Insert a new 250mm spoke into the hub.
      • Align the spoke with the spoke nipple in the rim.
      • Try to keep the spoke as straight as possible when threading it around the other spokes. Slight bends will be taken out when it is tightened.
      Vraag FixBot
      Voeg opmerking toe
    9. Giant Reign 2 Wheel Spoke Replacement: stap 13, afbeelding 1 van 1
      • Using an SW-1 spoke wrench, tighten the spoke.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sterling Grande
148 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-14, Amido Fall 2012 Lid van Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Leden
44 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 31
Altijd: 2,856
