Ga door naar hoofdinhoud
Giant Reign 2 Headset Replacement
Wat je nodig hebt
    1. Giant Reign 2 Headset Replacement, Hex Screws: stap 1, afbeelding 1 van 1
      • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
      Vraag FixBot
      Voeg opmerking toe
    2. Giant Reign 2 Headset Replacement, Axle Screw: stap 2, afbeelding 1 van 2 Giant Reign 2 Headset Replacement, Axle Screw: stap 2, afbeelding 2 van 2
      • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
      • Push the axle screw to reveal the axle rod on the other side.
      Vraag FixBot
      Voeg opmerking toe
    3. Giant Reign 2 Headset Replacement: stap 3, afbeelding 1 van 1
      • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
      • Hold the wheel when pulling out the axle rod so that the bike does not fall.
      Vraag FixBot
      Voeg opmerking toe
    4. Giant Reign 2 Headset Replacement, Front Wheel: stap 4, afbeelding 1 van 1
      • Pull the wheel from the fork.
      Vraag FixBot
      Voeg opmerking toe
    1. Giant Reign 2 Headset Replacement, Headset: stap 5, afbeelding 1 van 2 Giant Reign 2 Headset Replacement, Headset: stap 5, afbeelding 2 van 2
      • Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
      • If necessary use wire cutters to release zip ties attaching cables to the forks.
      Vraag FixBot
      Voeg opmerking toe
    2. Giant Reign 2 Headset Replacement: stap 6, afbeelding 1 van 3 Giant Reign 2 Headset Replacement: stap 6, afbeelding 2 van 3 Giant Reign 2 Headset Replacement: stap 6, afbeelding 3 van 3
      • Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam.
      • Using the 4mm Allen wrench, loosen the side screw on both sides.
      • Lift off the handlebar.
      • Hang the handlebar gently from the cables. Do not pull the cables as you may damage the brake/derailleur lines.
      Vraag FixBot
      Voeg opmerking toe
    3. Giant Reign 2 Headset Replacement: stap 7, afbeelding 1 van 3 Giant Reign 2 Headset Replacement: stap 7, afbeelding 2 van 3 Giant Reign 2 Headset Replacement: stap 7, afbeelding 3 van 3
      • Slide off the spacers.
      • Lift off the seal.
      Vraag FixBot
      Voeg opmerking toe
    4. Giant Reign 2 Headset Replacement: stap 8, afbeelding 1 van 1
      • Slide the fork out of the casing.
      Vraag FixBot
      Voeg opmerking toe
    5. Giant Reign 2 Headset Replacement: stap 9, afbeelding 1 van 1
      • Using your fingers, pry the bearings from the top and bottom of the headset.
      Vraag FixBot
      Voeg opmerking toe
    6. Giant Reign 2 Headset Replacement: stap 10, afbeelding 1 van 1
      • Apply WD-40 to both ends of the headset and bearings.
      • Dry headset and bearings with paper towels.
      • Repeat as necessary until clean.
      Vraag FixBot
      Voeg opmerking toe
    7. Giant Reign 2 Headset Replacement: stap 11, afbeelding 1 van 2 Giant Reign 2 Headset Replacement: stap 11, afbeelding 2 van 2
      • Using your finger, apply all-purpose lube to the bearings and each end of the headset.
      • Insert the bearings into the headset with the beveled side facing into the headset.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sterling Grande
148 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-14, Amido Fall 2012 Lid van Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Leden
44 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 49
Altijd: 4,703
