Ga door naar hoofdinhoud
GermGuardian AC4825E UV-C Bulb Replacement
Wat je nodig hebt
  1. GermGuardian AC4825E UV-C Bulb Replacement, HEPA Filter Unit: stap 1, afbeelding 1 van 1
    • Check if the purifier's power cord is plugged into an electrical outlet.
    • If it is plugged in, unplug the power cord.
  2. GermGuardian AC4825E UV-C Bulb Replacement: stap 2, afbeelding 1 van 2 GermGuardian AC4825E UV-C Bulb Replacement: stap 2, afbeelding 2 van 2
    • Grab the rear cover of the purifier with one finger on the Lock and Release button.
    • Press the button down, and pull the rear cover away from the purifier.
  3. GermGuardian AC4825E UV-C Bulb Replacement: stap 3, afbeelding 1 van 3 GermGuardian AC4825E UV-C Bulb Replacement: stap 3, afbeelding 2 van 3 GermGuardian AC4825E UV-C Bulb Replacement: stap 3, afbeelding 3 van 3
    • Use your hands to pull the HEPA filter out of the purifier.
    • After reassembly, push & hold the UV control button for 5 seconds to reset the filter change indicator.
  4. GermGuardian AC4825E UV-C Bulb Replacement, UV-C Bulb: stap 4, afbeelding 1 van 1
    • Remove the two screws from the metal UV-C shield by turning the screws counter-clockwise using a Phillips #00 screwdriver.
    • Grab and pull the UV-C shield away from the purifier to remove it.
  5. GermGuardian AC4825E UV-C Bulb Replacement: stap 5, afbeelding 1 van 3 GermGuardian AC4825E UV-C Bulb Replacement: stap 5, afbeelding 2 van 3 GermGuardian AC4825E UV-C Bulb Replacement: stap 5, afbeelding 3 van 3
    • Using a tissue or a clean cloth, reach into the exposed space and grab the UV-C bulb.
    • Pull the UV-C bulb out of the exposed space to remove the bulb from its socket.
    • After reassembly, press and hold the UV control button for 5 seconds to reset the UV bulb change indicator.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tim Lourenco
305 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-1, Mellen Spring 2022 Lid van UMass Dartmouth, Team 2-1, Mellen Spring 2022
UMASSD-MELLEN-S22S2G1
4 Leden
Één opmerking
you end after you pull the bulb out. do you put another bulb in (of course) is there a right/wrong way (which side up or down) then do you plug it back in prior to holding the uv button 5 seconds? do you turn it on prior to holding the uv button 5 seconds? Please explain in detail what I should do.
william estes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 99
Altijd: 1,841
