Ga door naar hoofdinhoud
GeeksPhone Keon Screen Replacement
Wat je nodig hebt
    1. GeeksPhone Keon Screen Replacement, Battery: stap 1, afbeelding 1 van 2 GeeksPhone Keon Screen Replacement, Battery: stap 1, afbeelding 2 van 2
      • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
      • Slide the plastic opening tool from the bottom of the phone to the top.
      • Use the plastic opening tool to free all the clips attached to the phone.
      Vraag FixBot
      Voeg opmerking toe
    2. GeeksPhone Keon Screen Replacement: stap 2, afbeelding 1 van 1
      • Lift the cover away from the phone.
      Vraag FixBot
      Voeg opmerking toe
    3. GeeksPhone Keon Screen Replacement: stap 3, afbeelding 1 van 1
      • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
      • Lift the battery with the plastic opening tool and finish removing battery by hand.
      Vraag FixBot
      Voeg opmerking toe
    1. GeeksPhone Keon Screen Replacement, Back Plate: stap 4, afbeelding 1 van 2 GeeksPhone Keon Screen Replacement, Back Plate: stap 4, afbeelding 2 van 2
      • Remove the two 5mm T4 screws on the sides of the small orange plate.
      Vraag FixBot
      Voeg opmerking toe
    2. GeeksPhone Keon Screen Replacement: stap 5, afbeelding 1 van 2 GeeksPhone Keon Screen Replacement: stap 5, afbeelding 2 van 2
      • Gently remove the small orange plate by pulling it down.
      Vraag FixBot
      Voeg opmerking toe
    3. GeeksPhone Keon Screen Replacement: stap 6, afbeelding 1 van 1
      • Remove the following screws securing the back plate to the device:
      • Two silver 2mm T3 screws
      • Five black 3mm T3 screws
      Vraag FixBot
      Voeg opmerking toe
    4. GeeksPhone Keon Screen Replacement: stap 7, afbeelding 1 van 3 GeeksPhone Keon Screen Replacement: stap 7, afbeelding 2 van 3 GeeksPhone Keon Screen Replacement: stap 7, afbeelding 3 van 3
      • Slightly lift up the bottom corner of the backplate.
      • Release the four clips on both sides by pulling them away from the device.
      Vraag FixBot
      Voeg opmerking toe
    5. GeeksPhone Keon Screen Replacement: stap 8, afbeelding 1 van 2 GeeksPhone Keon Screen Replacement: stap 8, afbeelding 2 van 2
      • Lift the backplate away from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. GeeksPhone Keon Screen Replacement, Motherboard: stap 9, afbeelding 1 van 2 GeeksPhone Keon Screen Replacement, Motherboard: stap 9, afbeelding 2 van 2
      • Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
      • Remove the wire from the bottom left of the motherboard by lifting it away from the device.
      • Remove the 2mm T3 screw in the upper left corner of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. GeeksPhone Keon Screen Replacement: stap 10, afbeelding 1 van 1
      • Lift the motherboard and remove the connector on the back by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
      Vraag FixBot
      Voeg opmerking toe
    3. GeeksPhone Keon Screen Replacement: stap 11, afbeelding 1 van 1
      • Remove the motherboard from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. GeeksPhone Keon Screen Replacement, Antenna: stap 12, afbeelding 1 van 1
      • Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
      • Unfasten the plastic clamps attached to the antenna.
      Vraag FixBot
      Voeg opmerking toe
    2. GeeksPhone Keon Screen Replacement: stap 13, afbeelding 1 van 3 GeeksPhone Keon Screen Replacement: stap 13, afbeelding 2 van 3 GeeksPhone Keon Screen Replacement: stap 13, afbeelding 3 van 3
      • Gently lift the antenna and flip it over to reveal a ZIF connector on the back.
      • Flip up the small retaining flap on the ZIF connector and pull the ribbon cable out.
      Vraag FixBot
      Voeg opmerking toe
    1. GeeksPhone Keon Screen Replacement, Screen: stap 14, afbeelding 1 van 2 GeeksPhone Keon Screen Replacement, Screen: stap 14, afbeelding 2 van 2
      • Use the metal spudger to gently lift up the back of the screen.
      Vraag FixBot
      Voeg opmerking toe
    2. GeeksPhone Keon Screen Replacement: stap 15, afbeelding 1 van 2 GeeksPhone Keon Screen Replacement: stap 15, afbeelding 2 van 2
      • Continue to lift up the screen until it is loose from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
DavidDrash
266 Reputatie
1 Handleiding geschreven
USF Tampa, Team 3-5, Eyestone Fall 2015 Lid van USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Leden
48 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 446
