Ga door naar hoofdinhoud
GeeksPhone Keon Motherboard Replacement
Wat je nodig hebt
  1. GeeksPhone Keon Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 GeeksPhone Keon Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    Vraag FixBot
    Voeg opmerking toe
  2. GeeksPhone Keon Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Lift the cover away from the phone.
    Vraag FixBot
    Voeg opmerking toe
  3. GeeksPhone Keon Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    Vraag FixBot
    Voeg opmerking toe
  4. GeeksPhone Keon Motherboard Replacement, Back Plate: stap 4, afbeelding 1 van 2 GeeksPhone Keon Motherboard Replacement, Back Plate: stap 4, afbeelding 2 van 2
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
    Vraag FixBot
    Voeg opmerking toe
  5. GeeksPhone Keon Motherboard Replacement: stap 5, afbeelding 1 van 2 GeeksPhone Keon Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Gently remove the small orange plate by pulling it down.
    Vraag FixBot
    Voeg opmerking toe
  6. GeeksPhone Keon Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
    Vraag FixBot
    Voeg opmerking toe
  7. GeeksPhone Keon Motherboard Replacement: stap 7, afbeelding 1 van 3 GeeksPhone Keon Motherboard Replacement: stap 7, afbeelding 2 van 3 GeeksPhone Keon Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
    Vraag FixBot
    Voeg opmerking toe
  8. GeeksPhone Keon Motherboard Replacement: stap 8, afbeelding 1 van 2 GeeksPhone Keon Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Lift the backplate away from the device.
    Vraag FixBot
    Voeg opmerking toe
  9. GeeksPhone Keon Motherboard Replacement, Motherboard: stap 9, afbeelding 1 van 2 GeeksPhone Keon Motherboard Replacement, Motherboard: stap 9, afbeelding 2 van 2
    • Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    • Remove the wire from the bottom left of the motherboard by lifting it away from the device.
    • Remove the 2mm T3 screw in the upper left corner of the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  10. GeeksPhone Keon Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Lift the motherboard and remove the connector on the back by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    Vraag FixBot
    Voeg opmerking toe
  11. GeeksPhone Keon Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Remove the motherboard from the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Yanni Worthington
343 Reputatie
3 handleidingen geschreven
USF Tampa, Team 3-5, Eyestone Fall 2015 Lid van USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 28
Altijd: 444
