Ga door naar hoofdinhoud
GeeksPhone Keon Camera Replacement
Wat je nodig hebt
    1. GeeksPhone Keon  Camera Replacement, Battery: stap 1, afbeelding 1 van 2 GeeksPhone Keon  Camera Replacement, Battery: stap 1, afbeelding 2 van 2
      • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
      • Slide the plastic opening tool from the bottom of the phone to the top.
      • Use the plastic opening tool to free all the clips attached to the phone.
      Vraag FixBot
      Voeg opmerking toe
    2. GeeksPhone Keon  Camera Replacement: stap 2, afbeelding 1 van 1
      • Lift the cover away from the phone.
      Vraag FixBot
      Voeg opmerking toe
    3. GeeksPhone Keon  Camera Replacement: stap 3, afbeelding 1 van 1
      • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
      • Lift the battery with the plastic opening tool and finish removing battery by hand.
      Vraag FixBot
      Voeg opmerking toe
    1. GeeksPhone Keon  Camera Replacement, Back Plate: stap 4, afbeelding 1 van 2 GeeksPhone Keon  Camera Replacement, Back Plate: stap 4, afbeelding 2 van 2
      • Remove the two 5mm T4 screws on the sides of the small orange plate.
      Vraag FixBot
      Voeg opmerking toe
    2. GeeksPhone Keon  Camera Replacement: stap 5, afbeelding 1 van 2 GeeksPhone Keon  Camera Replacement: stap 5, afbeelding 2 van 2
      • Gently remove the small orange plate by pulling it down.
      Vraag FixBot
      Voeg opmerking toe
    3. GeeksPhone Keon  Camera Replacement: stap 6, afbeelding 1 van 1
      • Remove the following screws securing the back plate to the device:
      • Two silver 2mm T3 screws
      • Five black 3mm T3 screws
      Vraag FixBot
      Voeg opmerking toe
    4. GeeksPhone Keon  Camera Replacement: stap 7, afbeelding 1 van 3 GeeksPhone Keon  Camera Replacement: stap 7, afbeelding 2 van 3 GeeksPhone Keon  Camera Replacement: stap 7, afbeelding 3 van 3
      • Slightly lift up the bottom corner of the backplate.
      • Release the four clips on both sides by pulling them away from the device.
      Vraag FixBot
      Voeg opmerking toe
    5. GeeksPhone Keon  Camera Replacement: stap 8, afbeelding 1 van 2 GeeksPhone Keon  Camera Replacement: stap 8, afbeelding 2 van 2
      • Lift the backplate away from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. GeeksPhone Keon  Camera Replacement, Camera: stap 9, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Lift the retaining flap on camera's ZIF connector.
      • Pull the ribbon cable away with tweezers.
      Vraag FixBot
      Voeg opmerking toe
    2. GeeksPhone Keon  Camera Replacement: stap 10, afbeelding 1 van 3 GeeksPhone Keon  Camera Replacement: stap 10, afbeelding 2 van 3 GeeksPhone Keon  Camera Replacement: stap 10, afbeelding 3 van 3
      • Carefully wiggle the camera away from the device.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order; but remember, the new camera must be glued back in place where the old one was removed.
Bryan Bittner
167 Reputatie
1 Handleiding geschreven
USF Tampa, Team 3-5, Eyestone Fall 2015 Lid van USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Leden
48 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 26
Altijd: 390
