Ga door naar hoofdinhoud
Gateway SA1 RAM Replacement
Wat je nodig hebt
  1. Gateway SA1 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Move the latch to the right of the battery to unlock.
    Vraag FixBot
    Voeg opmerking toe
  2. Gateway SA1 RAM Replacement: stap 2, afbeelding 1 van 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. Gateway SA1 RAM Replacement, RAM: stap 3, afbeelding 1 van 2 Gateway SA1 RAM Replacement, RAM: stap 3, afbeelding 2 van 2
    • Loosen the indicated Philips screw that connects the memory bay cover to the casing.
    • The indicated Philips screw does not come out of the cover.
    Vraag FixBot
    Voeg opmerking toe
  4. Gateway SA1 RAM Replacement: stap 4, afbeelding 1 van 2 Gateway SA1 RAM Replacement: stap 4, afbeelding 2 van 2
    • Lift and remove the cover using the spudger.
    Vraag FixBot
    Voeg opmerking toe
  5. Gateway SA1 RAM Replacement: stap 5, afbeelding 1 van 2 Gateway SA1 RAM Replacement: stap 5, afbeelding 2 van 2
    • Gently press the clip outwards.
    • The module will tilt up and can be pulled out of the slot.
    • There may be another memory module underneath so be sure to remove both.
    Vraag FixBot
    Voeg opmerking toe
  6. Gateway SA1 RAM Replacement: stap 6, afbeelding 1 van 1
    • To insert a new memory, slide the module into the slot at a 30 to 45 degree angle.
    • Place the first module into the bottom slot then the next module into the top slot.
    • These slots are keyed so verify that you are sliding the module in one direction.
    • Verify that the new memory modules are designed for your specific Gateway Laptop.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Diego Carteno
273 Reputatie
7 handleidingen geschreven
Cal Poly, Team 24-20, Regan Spring 2010 Lid van Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 34
Altijd: 6,069
