Ga door naar hoofdinhoud
Gateway SA1 Outer Casing Replacement
Wat je nodig hebt
  1. Gateway SA1 Outer Casing Replacement, Battery: stap 1, afbeelding 1 van 1
    • Move the latch to the right of the battery to unlock.
    Vraag FixBot
    Voeg opmerking toe
  2. Gateway SA1 Outer Casing Replacement: stap 2, afbeelding 1 van 1
    • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
    • The latch must be held in position to remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. Gateway SA1 Outer Casing Replacement, Disk Drive: stap 3, afbeelding 1 van 1
    • Unscrew the marked 5.9 mm Philips screw.
    Vraag FixBot
    Voeg opmerking toe
  4. Gateway SA1 Outer Casing Replacement: stap 4, afbeelding 1 van 1
    • Use the spudger to pry out the Disk dive.
    Vraag FixBot
    Voeg opmerking toe
  5. Gateway SA1 Outer Casing Replacement: stap 5, afbeelding 1 van 1
    • The disk drive should easily detach and can now be replaced.
    Vraag FixBot
    Voeg opmerking toe
  6. Gateway SA1 Outer Casing Replacement, Outer Casing: stap 6, afbeelding 1 van 1
    • Remove the twelve 5.9 mm Philips screws from the back cover.
    • Remove one 8.8 mm Philips screw from the back cover.
    Vraag FixBot
    Voeg opmerking toe
  7. Gateway SA1 Outer Casing Replacement: stap 7, afbeelding 1 van 3 Gateway SA1 Outer Casing Replacement: stap 7, afbeelding 2 van 3 Gateway SA1 Outer Casing Replacement: stap 7, afbeelding 3 van 3
    • Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery.
    • Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
    Vraag FixBot
    Voeg opmerking toe
  8. Gateway SA1 Outer Casing Replacement: stap 8, afbeelding 1 van 2 Gateway SA1 Outer Casing Replacement: stap 8, afbeelding 2 van 2
    • Remove the hinge covers by lifting each with the sharp point of the spudger.
    • Notice that the middle cover has a different shape and is more difficult to remove.
    Vraag FixBot
    Voeg opmerking toe
  9. Gateway SA1 Outer Casing Replacement: stap 9, afbeelding 1 van 3 Gateway SA1 Outer Casing Replacement: stap 9, afbeelding 2 van 3 Gateway SA1 Outer Casing Replacement: stap 9, afbeelding 3 van 3
    • There will be a connection underneath the speaker cover.
    • Remove the speaker cover using the spudger.
    Vraag FixBot
    Voeg opmerking toe
  10. Gateway SA1 Outer Casing Replacement: stap 10, afbeelding 1 van 1
    • Unscrew the two 3.9 mm Philips screws and remove the keyboard.
    Vraag FixBot
    Voeg opmerking toe
  11. Gateway SA1 Outer Casing Replacement: stap 11, afbeelding 1 van 3 Gateway SA1 Outer Casing Replacement: stap 11, afbeelding 2 van 3 Gateway SA1 Outer Casing Replacement: stap 11, afbeelding 3 van 3
    • Carefully lift the keyboard off from the laptop. It is still attached as shown.
    • Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away.
    • The brown colored component with the tabs does not come out with the connector.
    Vraag FixBot
    Voeg opmerking toe
  12. Gateway SA1 Outer Casing Replacement: stap 12, afbeelding 1 van 3 Gateway SA1 Outer Casing Replacement: stap 12, afbeelding 2 van 3 Gateway SA1 Outer Casing Replacement: stap 12, afbeelding 3 van 3
    • Lift up the black tab and gently pull out the connector.
    Vraag FixBot
    Voeg opmerking toe
  13. Gateway SA1 Outer Casing Replacement: stap 13, afbeelding 1 van 2 Gateway SA1 Outer Casing Replacement: stap 13, afbeelding 2 van 2
    • Unscrew the four marked 5.9 mm Philips screws.
    Vraag FixBot
    Voeg opmerking toe
  14. Gateway SA1 Outer Casing Replacement: stap 14, afbeelding 1 van 2 Gateway SA1 Outer Casing Replacement: stap 14, afbeelding 2 van 2
    • Move the wires out of the fixed space as shown.
    Vraag FixBot
    Voeg opmerking toe
  15. Gateway SA1 Outer Casing Replacement: stap 15, afbeelding 1 van 2 Gateway SA1 Outer Casing Replacement: stap 15, afbeelding 2 van 2
    • Unscrew the five marked 3.8 mm Philips screws.
    • Three screws are located on the right side of the screen.
    • Two screws are located on the left side of the screen.
    Vraag FixBot
    Voeg opmerking toe
  16. Gateway SA1 Outer Casing Replacement: stap 16, afbeelding 1 van 1
    • Remove the screen brackets from the computer's base.
    Vraag FixBot
    Voeg opmerking toe
  17. Gateway SA1 Outer Casing Replacement: stap 17, afbeelding 1 van 3 Gateway SA1 Outer Casing Replacement: stap 17, afbeelding 2 van 3 Gateway SA1 Outer Casing Replacement: stap 17, afbeelding 3 van 3
    • Remove the four 5.9 mm Philips screws as indicated:
    • There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo.
    • There are two similarly positioned screws on the right side.
    Vraag FixBot
    Voeg opmerking toe
  18. Gateway SA1 Outer Casing Replacement: stap 18, afbeelding 1 van 2 Gateway SA1 Outer Casing Replacement: stap 18, afbeelding 2 van 2
    • The following steps (18 - 20) explain how to remove the three indicated connections.
    • The order is Blue, Violet, Orange.
    • Lift the white tab up and gently take out the connector.
    Vraag FixBot
    Voeg opmerking toe
  19. Gateway SA1 Outer Casing Replacement: stap 19, afbeelding 1 van 1
    • Use the spudger to pull off the black attachment.
    Vraag FixBot
    Voeg opmerking toe
  20. Gateway SA1 Outer Casing Replacement: stap 20, afbeelding 1 van 1
    • Lift and pull the black tab upward until it becomes unattached.
    • Some force may be required.
    Vraag FixBot
    Voeg opmerking toe
  21. Gateway SA1 Outer Casing Replacement: stap 21, afbeelding 1 van 1
    • Use the spudger to remove the casing as seen in the picture.
    Vraag FixBot
    Voeg opmerking toe
  22. Gateway SA1 Outer Casing Replacement: stap 22, afbeelding 1 van 1
    • Remove the casing.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
6 andere personen hebben deze handleiding voltooid.
Diego Carteno
273 Reputatie
7 handleidingen geschreven
Cal Poly, Team 24-20, Regan Spring 2010 Lid van Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 40
Altijd: 16,479
