Ga door naar hoofdinhoud
Gateway NV52 Hard Drive Replacement
Wat je nodig hebt
  1. Gateway NV52 Hard Drive Replacement, Base Cover: stap 1, afbeelding 1 van 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Gateway NV52 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
    Vraag FixBot
    Voeg opmerking toe
  3. Gateway NV52 Hard Drive Replacement, Hard Drive Compartment: stap 3, afbeelding 1 van 1
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
    Vraag FixBot
    Voeg opmerking toe
  4. Gateway NV52 Hard Drive Replacement: stap 4, afbeelding 1 van 3 Gateway NV52 Hard Drive Replacement: stap 4, afbeelding 2 van 3 Gateway NV52 Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
    Vraag FixBot
    Voeg opmerking toe
  5. Gateway NV52 Hard Drive Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Remove the four identical 1/8" Phillip screws located in every corner of the Hard Drive using the Phillips #0 Screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. Gateway NV52 Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Access to the Hard drive by gently sliding the metal cover away from the Hard Drive.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Irma Marin
608 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-24, Regan Spring 2014 Lid van Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 33
Altijd: 4,076
