Ga door naar hoofdinhoud
Gateway NE52203u USB Port Replacement
Wat je nodig hebt
  1. Gateway NE52203u USB Port Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the device over onto its backside in order to access the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. Gateway NE52203u USB Port Replacement: stap 2, afbeelding 1 van 2 Gateway NE52203u USB Port Replacement: stap 2, afbeelding 2 van 2
    • Locate the battery release latch and slide it over to the other side.
    • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. Gateway NE52203u USB Port Replacement: stap 3, afbeelding 1 van 1
    • Grab the newly ejected battery from the device to completely remove it.
    • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
    Vraag FixBot
    Voeg opmerking toe
  4. Gateway NE52203u USB Port Replacement, Touchpad Assembly: stap 4, afbeelding 1 van 2 Gateway NE52203u USB Port Replacement, Touchpad Assembly: stap 4, afbeelding 2 van 2
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
    Vraag FixBot
    Voeg opmerking toe
  5. Gateway NE52203u USB Port Replacement: stap 5, afbeelding 1 van 1
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
    Vraag FixBot
    Voeg opmerking toe
  6. Gateway NE52203u USB Port Replacement: stap 6, afbeelding 1 van 2 Gateway NE52203u USB Port Replacement: stap 6, afbeelding 2 van 2
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
    Vraag FixBot
    Voeg opmerking toe
  7. Gateway NE52203u USB Port Replacement: stap 7, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
    Vraag FixBot
    Voeg opmerking toe
  8. Gateway NE52203u USB Port Replacement: stap 8, afbeelding 1 van 3 Gateway NE52203u USB Port Replacement: stap 8, afbeelding 2 van 3 Gateway NE52203u USB Port Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
    Vraag FixBot
    Voeg opmerking toe
  9. Gateway NE52203u USB Port Replacement, USB Port: stap 9, afbeelding 1 van 2 Gateway NE52203u USB Port Replacement, USB Port: stap 9, afbeelding 2 van 2
    • Using a spudger, pry the ZIF connector upwards.
    Vraag FixBot
    Voeg opmerking toe
  10. Gateway NE52203u USB Port Replacement: stap 10, afbeelding 1 van 1
    • Use your fingers to gently disconnect the ribbon wire from the USB circuit board.
    Vraag FixBot
    Voeg opmerking toe
  11. Gateway NE52203u USB Port Replacement: stap 11, afbeelding 1 van 1
    • Using a #00 Phillips head screwdriver, remove the 2.9 mm screw on the USB circuit board.
    Vraag FixBot
    Voeg opmerking toe
  12. Gateway NE52203u USB Port Replacement: stap 12, afbeelding 1 van 1
    • Finally, remove the old USB port.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Stephen Spees
542 Reputatie
4 handleidingen geschreven
Baylor, Team 2-1, Grigsby Spring 2015 Lid van Baylor, Team 2-1, Grigsby Spring 2015
BU-GRIGSBY-S15S2G1
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 934
